Air Wings, Lowers or windshield
Old Sep 21, 2012 | 02:37 PM
tlar1540's Avatar
tlar1540
Default Air Wings, Lowers or windshield
Not sure if I should post this here or not but I figured I would get better answers on this side of the fence.. I have an 08 Heritage with a Kuryakyn batwing fairing on it and I'm wondering what you guys did to help with wind. Not sure if I should try a different windshiled, air wings, or some lowers. I know if I put my feet on top of the engine guard the wind is virtually gone, so not sure if lowers would help or if the air wings would be better. Appreciate what worked for the guys running a batwing fairing..
Thanks!!
Old Sep 21, 2012 | 03:31 PM
mkguitar's Avatar
mkguitar
the bigger hole you push through air, the larger and deeper the low pressure zone in the cockpit.
air rushes to fill this low pressure zone from the sides, above and below and the rear.
the key ( for me) is to reduce the pressure differential.
so, windscreen is cut down to where the wind blast hits right where my hairline used to be. - this throws most of the grit and bugs just over my head.
and I use fairing mounted wind deflectors to direct air INTO the cockpit. this controlled high pressure air helps to offset the pressure differential in the cockpit, and is a factor I can control.
and 3.) expectations need to be realistic.
some guys seem to add every deflector and trick in the book when they'd be more comfortable in the mini van ( with Harley sticker in the rear window)
I do use fairing lowers but not for any kind of buffeting issue
a.) they enhance the "teardrop" profile of the Harley Touring bike which I like
b.) increased air flow to the motor- cooling
c.) leg protection from the elements makes for less rider fatigue
Mike
Old Sep 21, 2012 | 03:38 PM
tlar1540's Avatar
tlar1540
Thanks for the education Mike. I'm not expecting it to be as calm as a mini van but would like it to be a bit better than what it is now. I can tell you that the way better now with the fairing on it than it was with the stock windshield but also know it can be improved a bit. I don't mind the wind in my face but with the cooler temps coming in, I would like a bit more protection.
Old Sep 21, 2012 | 03:51 PM
fightingmajor's Avatar
fightingmajor
Check out this discussion https://www.hdforums.com/forum/touri...fantastic.html
Old Sep 21, 2012 | 05:47 PM
0ldhippie's Avatar
0ldhippie
Imho the batwing is the worst thing ya could have done for buffeting. I got all the deflectors and lowers, still not happy like my old roadglide or even road king? Sorry I'm little help but, each gadget helps some.
Old Sep 21, 2012 | 08:01 PM
rleggs's Avatar
rleggs
Try a set of the roadglide wind deflectors that snap to your crash bar and tank bolts. I added a set to my Ultra and they killed alot of the under the fairing buffing. The're about $30 at your HD dealer.
Old Sep 24, 2012 | 02:46 PM
leadermc's Avatar
leadermc
Former Sponsor
Simple but effective - and it will keep you warmer since you mentioned that would be a plus (we ride in MN, we know all about that) - is the rain guards that fasten over the crash bar: http://www.leadermotorcycle.com/harl...n-rain-guards/ (these are not like the HD similiar product, nicer material, no temp restriction, easy on/off...)
Old Sep 24, 2012 | 02:52 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
There are so many factors and really you have to experiment and figure out what works for you. There are some solid suggestions, but if you start looking for a new shield, let us know and we'll help you out however we can.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
cmhdwg09
May 11, 2019 06:55 PM
LADNAR
Oct 15, 2013 11:10 AM
theindian
Mar 11, 2011 08:56 PM
Texas Rapier
Aug 1, 2010 05:00 PM
Thundercloud
Nov 6, 2006 07:47 PM
