so i road to work this morning with the heated seat on (60* outside) & i didnt really notice much heat on my butt. maybe it just needs to be colder out before i get too disappointed. have you guys noticed it getting hot or just slightly warm?
Oh no, Mine will get hot enough to make your azz sweat. Sorry for the mental image but just letting you know.
so this has me stumped why it doesnt get hot on either seat. guess ill call the service department to see if i can get them to give me some info on why this seat wont get hot.
its got power.
do the switches light up at all when you guys turn the seat in or when you turn the ignition on?
ok...so i found the plug that you gents speak of
& it does have switched power & is not effected by the acc switch nect to the cruise switch, witch is a good thing for me (cause im using that switch for my ditch lights).
I have a Street Glide and I have to use the Acc switch to get power to the plug under the seat. If your seat plugs into the empty plug in front of your fuse box and you are not using the Acc button then either your not using the right plug (but there should only be one that it fits) or when you wired your ditch lights you disconnected something from your Acc button to make them work.
Harley makes a switch circuit adapter to be able to plug two items into the Acc plug.
Here is a link to the sunray heated seat that has the pdf installation instructions attached so you can see the plug and read were to install.
its got power.
I've never bothered to look at the lights one the switch. I'll check them in a little bit and post back.
thanks for the info, that was good to read.
i did have to change the pins in the connector because of how i wired my ditch lights but i made sure i have 12v where it needs to be & that the neg side is also in the correct location. (in that acc plug you have two sets of acc switched wires. one set that just runs off the ign switch & the other set runs off the ign too but is controlled by the acc switch by the cruise switch)
thank you for your help that was great info.
thanks for checking
Originally Posted by hd_rolling
No lights on mine.
thanks for checking. the switches on my seat do NOT light up either. i just thought they might cause most everything else does nowadays.
