Front suspension input
Old Nov 30, 2012 | 10:58 AM
troop's Avatar
troop
Default Front suspension input
After getting some real good advise for the shocks, I'm shifting my focus to the forks. On past metric bikes, I've had nice improvement with just a Progressive spring swap but they were very easy as the fork tube bolts were wide out in the open and the springs were cheap at $60. Not so with the FLHT I've basically ruled out monotubes and am looking at a Race Tech (straight wound)/Progressive (progressive wound) springs along with either emulators or eliminaters. Never used straight wound fork springs before so not sure how they work/feel on a heavy bike? I know at my 215# I need the 1.0kg springs. Input appreciated.. Thx
Old Nov 30, 2012 | 11:01 AM
Fire-Medic's Avatar
Fire-Medic
Tagged for info, you basically started the thread I was going to, only difference is I got 20 lbs on you
Old Nov 30, 2012 | 11:49 AM
xwhyz1959's Avatar
xwhyz1959
read this....
https://www.hdforums.com/forum/touri...rk-better.html
Old Nov 30, 2012 | 12:19 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Race Tech Springs and modified Intiminators.......Do a search here and you're get plenty of help & opinions to help you decide....
Old Nov 30, 2012 | 12:35 PM
y2kflhr's Avatar
y2kflhr
this seems to be the way to go, I have the intiminators (non modded), and I am going with straight rate springs, I have progressive lowers on my ultra, and its ok, but with ny roads so bad I want to try a straight rate springs
Old Nov 30, 2012 | 01:16 PM
0ldhippie's Avatar
0ldhippie
Go here!
Old Nov 30, 2012 | 01:31 PM
rooti's Avatar
rooti
I think you will love that set up....Nothing really better unless you spend a lot more money
Old Nov 30, 2012 | 01:47 PM
d-streetglidr's Avatar
d-streetglidr
From: South Carolina-First to secede and hopefully the next.
Modded Intiminators + new springs = Monotube$$
I went with the Monotubes based on what I've read on this and other forums. Not bad mouthing other solutions. I just went with what I felt comfortable with.
Old Nov 30, 2012 | 03:13 PM
46u's Avatar
46u
90K still running the stock suspension and about 3 months ago put a HD sidecar on it. I see no need to change mine. Maybe 10 times in the 90k I bottom any of it suspension out what made them bottom out does not matter what you where riding it would bottom out.
Old Nov 30, 2012 | 05:17 PM
fabrik8r's Avatar
fabrik8r
While the cost of the Monotubes and the Intiminator setup is about the same, and the amount of work is about the same, the monotubes are a one-size-fits-all product, there is nothing tunable about them. I don't see the point in going from an OEM one-size-fits-all suspension to an aftermarket one-size-fits-all suspension, even if it is an improvement. With the Ricors it requires a very small amount of additional work to achieve a suspension tuned to the individual. Also the Ricors are the only "inertia" valve product available for the front end. So far not one person has reported anything less than exceptional results with the modified Intiminator set up. I'm happy to help anyone who wants to do it, just hit me with a PM.
