Noise from starter area when starting
Old Jan 7, 2013 | 06:17 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Originally Posted by customsoftail200
So I broke out the volt meter today. I had 12.1v ignition off, 11.76 ignition on, cranked it dropped to 5.9v then to 8.0v. F'n junk batteries, it's not that old and spends a lot of time on a tender. Who makes the best batteries for a bagger?
Does the starter make the noise first start off the charger or after you ride awhile?
This sounds like the voltage regulator. A 12 Volt battery should jump to 14 volts when the motor is running and 12 when the motor is shut off. The charging system sounds suspect as the voltage of your battery is at 12 volts before the electronic systems are used with the motor running. Not sure but I think at least 13.8 volts should be read with a digital multi-meter acrocss the battery with engine running.
Old Jan 7, 2013 | 06:50 PM
customsoftail200's Avatar
customsoftail200
It usually makes the noise first start of the day or after it sits for a while. Hot starts are usually good.
Charging system is fine, at idle I'm at 13.9-14.1V. I borrowed a buddies known good battery and the noise is still there. When I hit the start button it engages for a second, then I get a really loud "clanking" noise, it stops cranking then engages again and may or may not turn over until it starts. Sometimes it will make the noise again, stop and re-engage. I'm not sure where to go now. New Hi-torq starter, battery and jack shaft???
Old Jan 7, 2013 | 07:00 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
My BIL had the same problem with his 116 ci in his Dyna.
Originally he replaced the starter with (??? ) some hi torque brand and found it to be junk. He cmm'd the starter and the hi-torqe, hi dollar starter armature was off center. JUNK is what it was. At that point that starter took out the ring gear.
We changed the starter gear and ring gear to gain starter torque, then added a Big Bore battery and the problem went away. He's been riding it now for 4 years. He kept the stock starter in place.
Old Jan 7, 2013 | 07:04 PM
customsoftail200
Nope. Thats not it either.
Old Jan 7, 2013 | 07:56 PM
customsoftail200
I did that already.. I think the ring gear is like 66T and a 9T starter gear.
Old Jan 7, 2013 | 09:28 PM
JimTJr's Avatar
JimTJr
My bike has done since new, I thought it was the compensator,, loud clunking and stops for a second,, then release the button and try again it starts
Old Jan 8, 2013 | 07:09 AM
Scrmnvtwins
I had this problem on my '89 EVO and my fix may not be what you are looking for. Basically I took the end off the starter solenoid, drilled a hole through the center, installed a shoulder bolt and spring, then used the sholder bolt to manually engage the starter. Pushing in the solenoid plunger by hand does not allow the solenoid to back out and keeps the starter engaged. You can buy this through J&P for a $few. You can try this bysimply pulling the cover off the end of the starter and push the solenoid plunger in with a tool, maybe a piece of dowel rod. Anyway if it works, easy to install the J&P plunger or make your own.
Old Jan 11, 2013 | 07:17 PM
customsoftail200
Ok, so I pulled the trigger and bought a 1.8kW starter and holy s##t! The bike has NEVER started so easy. No noises, no nothing..
hooter23
Engine Mechanical Topics
Jun 22, 2014 01:14 PM
ptowncpt
Jan 9, 2013 06:44 AM
RoadRich2010
Jan 4, 2012 09:31 PM
dbru899271
Nov 15, 2011 05:33 PM
vascik883
Dec 13, 2009 07:57 AM
