handle bar adjustment questions....need help!
- I was able to get the ignition off and the piece that covers the handlebar clamp bolts (with the four blank switches)
But I can't get to the bolts to loosen them as the inner fairing covers them and I don't want to scratch it...
Two questions:
- I heard guys saying that they were able to adjust the handlebars without removing the inner fairing...how is that done without scratching the fairing part just under the radio?
- My ignition is out of alignment and I can't get the switch back on properly...manual says to use an alignment tool but an Indy told me that they don't use the tool. Anyone know how to realign the ignition so the switch goes back on properly?
Cheers,
mickey
you should be able to adjust the bars pretty easily, no need to pull the radio
1 put a BIG thick towel over you tank.
2. the bars are held by 2 clamps, you only have to loosen the back side of the clamps to get some play.
under the trim piece under the radio, you should see 2 allen head bolts.
use a screwdriver bit from your 1/4" set-- put the bit in the allen, butt end first.
you should have enough of the bit sticking up, that you can turn it with a 1/4" wrench to loosen and later, tighten
( this same trick is great for the allens on the tranny end cover, you can tighten them with out removing the exhaust)
or you can hacksaw a short piece off of your allen key set and use that- same method.
once loosened, rotate the bars to the new position
tighten them.
MAKE SURE that you have at least 3/4" clearance between the controls and the tank- remember that even as tight as tight can be, the bars are on rubber bushings and they will move in the bushings if leaned on. check this clearance at full lock, left and right
Mike
Two questions:
Cheers,
mickey
For the ignition assy, just make an alignment tool from copper tubing, or use thin flat-heat screwdriver. Need to look & understand how everything in the ignition aligns (like a puzzle). Here's the video:
Once you have it, it's easy to repeat. Good luck!
