compression releases
Old Jan 31, 2013 | 08:41 AM
BJFLHT's Avatar
BJFLHT
Default compression releases
With the proper camshaft, are they needed in a 10:1 motor?
Old Jan 31, 2013 | 08:48 AM
Frankenbagger's Avatar
Frankenbagger
Probably, but it depends on your ccp. Anything up towards 190psi and over and you should have them IMO. My guess is that at 10:1 unless your cam has a pretty large overlap you're gonna be close to 190psi.
theres some calculators on this website that help calculate your static compression and calculate ccp with a library of cams.
http://www.bigboyzcycles.com/calculators.htm
My .02, its like $100 to install them while the heads are off. Just do it. If you try to save a bill and need them down the road youre gonna kick yourself while having to pull the heads again
Old Jan 31, 2013 | 11:34 AM
mkguitar's Avatar
mkguitar
Originally Posted by Frankenbagger
.... If you try to save a bill and need them down the road youre gonna kick yourself while having to pull the heads again
after laying out the cash for broken starters...
the compression release is there to allow the motor to get some momentum before compression.
our motors do not have big flywheel mass to store rotational energy so ACRs are a great addition
mike
Old Jan 31, 2013 | 04:01 PM
JJHOG's Avatar
JJHOG
If you dont' want to spend the money on the ACR's then have them install the MCR's like I did. Makes people wonder what your doing reaching down by your spark plugs just before you start your engine. The manuals pop back out from the motors compression once it starts so it's not like you have to reach back down again.
Old Jan 31, 2013 | 04:22 PM
Uncle Larry's Avatar
Uncle Larry
You haven't stated what your build will be ... you might consider S&S Easy Start Cams ... they have a mechanical "compression release" built in and they work quite nicely.
http://www.sscycle.com/feature/featureview.php?s_id=10
Old Jan 31, 2013 | 05:00 PM
0ldhippie's Avatar
0ldhippie
There are tons of folks running 10-1 103 cast pistons without compression releases. There are also folks replacing starters. Are ya feeling lucky? Well are ya?
Old Jan 31, 2013 | 06:03 PM
DTTJGlide's Avatar
DTTJGlide
Why doesn't anybody give a little more o\info when asking a ? Like what cams, what year bike, what size engine, they all make a difference. I'm just picking on you, but so many people give little or no info & expect a reasonable answer. If it's an 07 or newer, yes!
Old Jan 31, 2013 | 07:18 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Yes they are worth it. It isnt the starters that are the first to go with the added compression...its the ring gear when the starter kicks out and chips a tooth...or two. Pre 08' you could replace the ring gear easily.....the 08's and later you get to replace the clutch basket too. Ohhhh...next will be the starter drive.
I just built a 107 with Woods TW777 cams...it'll start without pushing in the manual releases...however it cranks a whole lot easier with the buttons pushed in....Doesn't sound near as nasty when the starter drive kicks out either.
I purchased these....http://www.ebay.com/itm/150951860516...84.m1439.l2649
The button on mine were black...sweet they match my bike, lol
They work just like the Jims ones I paid 3x that for on my last build....these aren't rocket science. Save some money buy em'.
Old Jan 31, 2013 | 07:57 PM
UltraNutZ's Avatar
UltraNutZ
Old Jan 31, 2013 | 08:45 PM
Jasper86's Avatar
Jasper86
i'm @ about 10.2:1 on my evo, and i had Bean @ BBC in maine put MCR's in my heads.
in the cold: dont need em. spins pretty good (and starts FAST). once shes good and warm though, she definitely cranks a bit easier with them pushed in. (this is with a W6....already debating going bigger and picking up a W8)
i'm @ (calculated) ~ 195psi cranking pressure on the original starter from 1998 (did lose a starter clutch, once, although that was before I bumped the CR to 10.2:1)
