What is this sensor and why might it be leaking?
Old Feb 19, 2013 | 04:42 PM
TheBurninator's Avatar
TheBurninator
Default What is this sensor and why might it be leaking?
Hope this isn't a stupid question. I'm trying to get my street glide ready for a long trip and upon inspection found a wet spot near this connector. For reference, it is on the left side of the bike below what I think is the crank position sensor. What is this sensor and why might it be leaking? Just trying to figure out if this is something I can fix easily or not?
Thanks in advance for your help!
Roger
Attached Thumbnails What is this sensor and why might it be leaking?-sensor.jpg
Old Feb 19, 2013 | 04:50 PM
Keithhu's Avatar
Keithhu
Looks like your stator plug? Common leak point
Old Feb 19, 2013 | 04:54 PM
craigffb's Avatar
craigffb
From the OPs description and looking at the picture I agree.
Old Feb 19, 2013 | 04:57 PM
flhrbill's Avatar
flhrbill
https://www.hdforums.com/forum/touri...or-wiring.html
Check this forum link or do a search for stator leak. Very common problem. I fixed mine by cleaning the area and making sure it was dry, then I applied a good sealant around the plug. Many remedies listed if you do a search.
Old Feb 19, 2013 | 05:01 PM
2black1s's Avatar
2black1s
Here you go...
https://www.hdforums.com/forum/touri...-oil-leak.html
From what I can see in your picture the leak doesn't look too bad and I wouldn't worry about any damage between now and whenever you fix it.
Old Feb 19, 2013 | 05:07 PM
Keithhu's Avatar
Keithhu
http://www.google.com/search?q=stato...hrome&ie=UTF-8
Old Feb 19, 2013 | 05:46 PM
1st 96 ultra's Avatar
1st 96 ultra
Old Feb 19, 2013 | 06:20 PM
TheBurninator
Thanks guys, I knew you would have a quick answer!! Thanks for the links, now that I know what it is, I can go about getting it fixed. Did I mention this forum and its members totally rock?!?
Old Feb 21, 2013 | 07:55 PM
Punjabi Rider's Avatar
Punjabi Rider
Its fairly common don't worry about it you can come back from your long ride and fix it.
traveler1
Oil Archive (no new posts)
Jun 23, 2018 08:33 PM
MasterGunz1775
May 9, 2017 07:21 AM
14longshot
Jul 22, 2014 10:24 PM
8828alex
Exhaust System Topics
Jan 26, 2013 05:23 PM
midnitewolf
Nov 21, 2010 01:37 PM
