Steering Head Grease ?
Old Mar 21, 2013 | 07:09 PM
Ultra Pearl's Avatar
Ultra Pearl
Default Steering Head Grease ?
Just adding a few new parts and doing spring/out of storage check up on my 08 Ultra.
How do you guys grease the steering head grease nipple.
Other than taking apart the front, the only way I see to get a grease gun on there is to swap put the nipple with a 45 or 90 degree one.
Any thoughts?
Old Mar 21, 2013 | 07:15 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Yes that Zerk fitting is hard to get to, but you should be able to reach it with a flexible hose type of grease gun.
Old Mar 21, 2013 | 07:17 PM
jus2anoyu's Avatar
jus2anoyu
I picked up a 90* adapter for my grease gun at advance auto parts for a few bucks and it works perfectly...
Old Mar 21, 2013 | 07:34 PM
Ultra Pearl
Thanks I'll check out getting one of those.
Now how much grease would that nipple take, because I can't see the grease getting to the steering head bearings where the nipple is placed.
Old Mar 21, 2013 | 07:38 PM
flatfifth2003's Avatar
flatfifth2003
just put a 45 degree zerk fitting on it, cheap and simple
Old Mar 21, 2013 | 07:48 PM
Lowcountry Joe
It varies, but usually several pumps to get new grease oozing out around the bearings on both ends. Some guys report using most of a tube on the initial greasing of the neck.
Be sure an use some high temp grease so it don't melt in really hot weather and drip all over your fender and the front of your motor. Makes a mess. I use that Lucas Red n Tacky. It's a high temp grease I picked up at Tractor Supply but it and other greases that are just as good are easy to find.
Old Mar 21, 2013 | 08:02 PM
Ultra Pearl
Thats what Iwas thinking....Thanks for the replys
Old Mar 21, 2013 | 08:10 PM
bberck's Avatar
bberck
That one is a piece of cake compared to some on my old 4 wheeler, so I already had a small one with a flexible hose that works good.
Notgrownup's Avatar
Notgrownup
I like that red n tacky Lucas hi temp grease...fill her up until it start oozing a bit.
Old Mar 21, 2013 | 08:11 PM
bagman1's Avatar
bagman1
A trick I learned is to wrape a piece of rope around the bottom of the neck, this will keep the grease from oozing out until the top bearing gets some grease. Agree with the correct grease so it doesnt melt out all over your fender in the heat.
