Help: High Oil Pressure
Old Apr 6, 2013 | 09:13 PM
mr_reality's Avatar
mr_reality
Exclamation Help: High Oil Pressure
OK guys I have a 2013 EGC that is running high oil pressure. The bike has less than 100 miles on it. The pressure is reading about 45 idling when cold and running 50-60 down the highway. My other 103 never ran this kind of pressure. Think its a bad sending unit or something bigger. Thanks for the help.
Old Apr 6, 2013 | 09:20 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
Let your dealer know - it's under warranty.
Old Apr 6, 2013 | 09:32 PM
Iceman24's Avatar
Iceman24
Seems like your oil gauge or sending unit's not functioning properly...still time for a warranty looksee...
Old Apr 6, 2013 | 09:33 PM
jus2anoyu's Avatar
jus2anoyu
Now that's a first. A harley with high oil pressure? What you describe really isn't that far above the norm for a new bike. You'll know when it drops to normal, the lifters will start ticking!
Old Apr 6, 2013 | 09:35 PM
mr_reality's Avatar
mr_reality
I have to give a big shout out of praise to my dealership, Bowling Green Harley Davidson. I posted a question on their service appointment request at 9:00pm tonight and got a response from both the service manager and the general manager of the store. Service manager agrees that its probably just a sending unit or bad gauge but wants me to run it in for a test.
Old Apr 6, 2013 | 09:36 PM
Larry Green's Avatar
Larry Green
My 12 ultra runs about the same it has 1,500 miles on it.
Old Apr 6, 2013 | 09:39 PM
QC's Avatar
QC
Having a relatively new high volume pump from when I did the cam upgrade, I'm running 45-50 cold, 15-20 at hot idle. Better than the 5 at hot idle I was running. This is measured with an Autometer rocker box gauge. A new engine would run relatively high I would think.
Old Apr 6, 2013 | 09:42 PM
Punjabi Rider's Avatar
Punjabi Rider
Its not for real probably just electronic glitch most likely.
Old Apr 6, 2013 | 10:05 PM
Jackie Paper's Avatar
Jackie Paper
Might want to read Wikipedia's 'Harley-Davidson Twin Cam engine' if you have modified the base idle oil pressure above 11 lbs or so since this is the open pressure limit for the oil injectors at the base of the cylinders. They should not be open at idle rpm levels since it tends to over heat the oil. If you have an oil cooler, engineering may have changed that. What does the owners manual say?
highwayking
Sep 30, 2013 07:19 PM
FL-kruzen
Jul 13, 2013 10:30 AM
smithbrl
Jun 20, 2012 12:55 AM
SKOOTERBUM
Oil Archive (no new posts)
Jul 11, 2007 09:07 PM
SKOOTERBUM
Jul 11, 2007 08:57 PM
