Plasma Rods installed!
Old Apr 8, 2013 | 09:04 AM
SDVmnt's Avatar
SDVmnt
Default Plasma Rods installed!
Installed the 8" Custom Dynamics Plasma rods over the weekend.
I used the Brake/Turn configuration. Didn't want the run lights.
Wiring was as easy as, install Posi Locks on the 2 purple wires to the right of the tri-bar Street Glide Facia (throttle side). Connect red wire to posi lock and both black wires from each Plasma Rod to the black wire.
Mounted the plasma rods with the 1/4 Round method as seen in other posts.
Extremely bright. In the sunlight it definitely shows how dim the stock dual light bar is.
If you're afraid of the technical difficulties, don't be!
Special thanks to Basselopes work here:
https://www.hdforums.com/forum/touri...2012-flhx.html
Old Apr 8, 2013 | 10:20 AM
TURQ's Avatar
TURQ
Thanks for the review, mine finally go on this week so I'm glad to hear they are good in bright daylight. I am also adding CD LED turn signals. BTW, great looking bike. How do you like the handle bars?
Old Apr 8, 2013 | 10:32 AM
SDVmnt's Avatar
SDVmnt
Thanks, They're PYO 12" bars. I'm 6'1 and the stock bars destroyed my shoulders. The bars are the perfect height for me with my seat combined with height. Super comfortable and just high enough to make the fairing blow the air over my hands.
FYI, if using the lights in Brake/Turn configuration means you don't need the PDC's. The first Gal I talked to at CD said I needed them. Called again on Friday to double check my gameplan and she said just wire them right in. The circuitry in tri-bar light will take care of it.
Old Apr 16, 2013 | 01:04 AM
smasharr's Avatar
smasharr
1st Gear
Default Video of Custom dynamics plasma rods and LEDs
Old Apr 16, 2013 | 01:11 AM
Dr. Tiki's Avatar
Dr. Tiki
Maybe mine are older and not as bright but I find that they are barely seen during the day.
Old Apr 16, 2013 | 01:20 AM
sublime_ac's Avatar
sublime_ac
My '12 has them as the only form of rear lights, run, brake and turn.. They work great.
Old Apr 16, 2013 | 01:34 AM
BrownSanta's Avatar
BrownSanta
love mine works great!
pegskraper
Mar 11, 2018 04:02 PM
Reindeer
Jun 19, 2012 10:23 PM
h2o
Electrical/Lighting/Alarm
Mar 13, 2011 07:00 PM
Jonn2002
Nov 15, 2009 08:58 PM
blukrom
Sep 3, 2005 07:00 PM
