Liscense plate relocation '06 FLHTCI
Old Feb 20, 2007 | 11:27 AM
Rob2002's Avatar
Rob2002
Default Liscense plate relocation '06 FLHTCI
I'd like to install the 2up tour pack dock station on the '06 Electraglide Classic. Anyone have any ideas on the relocation of the liscense plate? Don't want to use the HD relocation kit. (Don't need/want some of the parts) Any ideas?
Rob2002
Old Feb 20, 2007 | 11:38 AM
RonH's Avatar
RonH
Default RE: Liscense plate relocation '06 FLHTCI
On mine (same bike) when I put on the detachable tourpack docking stuff, I just took a flat chrome piece from and old cat eye plate/tailight combination I ran on my chooper and cut it rectangular, drilled a couple holes and bolted it into the bar where the original plate went. Works great and didn't cost a dime....
Old Feb 20, 2007 | 04:18 PM
gambler's Avatar
gambler
Kuryakyn sells a license plate holder that positions the plate lower so that it fits under the quick detach bracket for the tourpak. Works great.
Old Feb 20, 2007 | 04:25 PM
Harleypingman's Avatar
Harleypingman
When I removed the license plate mount from my '04 EG I attached the license plate to the left side saddlebag rails using a plain chrome HD license plate frame (about $15) and zip ties. It looked good and cleaned up the rear fender.
Another alternative is Kury part no. 2098, which is a license plate relocation kit that includes bullet turn signals and mounts the plate beneath the tailight. It's very similar to HD's license plate relocation kit that sells for $250. The Kury kit is $139.
Old Feb 20, 2007 | 07:55 PM
soos's Avatar
soos
ORIGINAL: Rob2002
Rob2002
Which relocation kit would that be? I just went detachable on my 06 EG Classic and used the HD Layback kit #53385-00. No problem at all. Don't believe the footnote about it not fitting, that's BS.
Old Feb 21, 2007 | 10:34 AM
Rob2002's Avatar
Rob2002
Thanks for the input guys.
I read the same thing about the layback kit.
Great info!
Love this forum!
Old Feb 21, 2007 | 12:08 PM
Cryptoboy's Avatar
Cryptoboy
Kuryaken makes another relocation kit that moves the place below the tailight, and changes the rear turn signals from the flat pancake style to the bullets. Just a bit over $100 for the part (not including the option curved license plate holder). It also has it's own light for the plate as well.
I'm probably going to get this piece myself, it really cleans up the look of the rear (to me at least).
Old Feb 21, 2007 | 01:03 PM
JoeR's Avatar
JoeR
6th Gear
I used the Harley Layback Licenses plate kit. Took a dremel tool and slotted the bolt holes a little. Works fine with plenty of clearance for the tork-pak.
Old Feb 21, 2007 | 02:55 PM
gambler's Avatar
gambler
I tried the layback kit, and it didn't quite clear the quick detachbracket on my 05 Ultra. That is why I ended up with the Kuryakyn bracket. Slotting the bolt holes probably would have worked.
Road Star
Oct 15, 2021 02:24 AM
skian
Feb 12, 2018 11:51 AM
Tinker55
Feb 27, 2015 11:29 AM
Silvio
Oct 29, 2013 12:29 PM
