2002 Ultra EFI Throttle Cable Help
Old May 13, 2013 | 12:21 PM
Catmanjoe's Avatar
Catmanjoe
6th Gear
Question 2002 Ultra EFI Throttle Cable Help
While cleaning the bike I noticed the front throttle cable seemed a little sloppy. I also noticed the throttle grip had to be twisted a little before tension is felt. I messed with the adjustment under the boot near the grip and don't know if I messed it up or not. How do I make sure the adjustment is proper before riding. The bike seems to to idle fine but don't want to take chances. Didn't mess with anything else. Any suggestions. I have the factory manual. Not much help there.
Old May 13, 2013 | 01:43 PM
grbrown's Avatar
grbrown
I have found that if there is too little slack in the throttle cables it is more difficult to control things smooooothly! You're not taking any chances, except perhaps missing those last few percent of full throttle.
As for your manual, both my 1990 and 2011 books have a section entitled Throttle Control. Go take a closer look!
Old May 13, 2013 | 06:33 PM
hdbob2006's Avatar
hdbob2006
I took some slack out of mine too,but the manual goes into a sort of confusing deal with adjusting the cruise cable at the same time. Didn't want to go too far with the throttle and botch up the cruise,so I left some slack in it.
Old May 14, 2013 | 07:10 AM
Paniolo's Avatar
Paniolo
And check the play with the bars turned. Make sure the throttle doesn't stick when the bars are in the left and right side fully locked position. A couple of years ago I had a rider in class who could not control their throttle. Came to find out it was sticking when the bars were turned. That's a safety issue.
Old May 14, 2013 | 07:42 AM
Catmanjoe's Avatar
Catmanjoe
6th Gear
Default Throttle
I turned the front wheel fully to the left and right and worked the throttle. Doesn't seem to be sticking. I am taking the bike to get inspected after work today. I'll let you all know if it works properly. Thanks for the replies.
Old May 15, 2013 | 09:06 AM
Catmanjoe's Avatar
Catmanjoe
6th Gear
Took the bike to get inspected and the throttle worked but didn't get to use the cruise control. It started to rain. It still has a little more play than I would like. I don't know which way to turn the threaded part of the cable to take up some of the play. Anyone got any ideas?
Old May 15, 2013 | 09:08 AM
grbrown's Avatar
grbrown
Read you manual, as per my post #2! It's all there.
Old May 17, 2013 | 10:42 AM
Catmanjoe's Avatar
Catmanjoe
6th Gear
Default Throtle Adjustment
Got the throttle taken care of. Stopped at the local Harley Dealer and they did the adjustment in about two minutes. I noticed the mechanic adusted both cables at the same time. I was only messing with the front one. The throttle is perfect now. Thanks for the replies.
Old May 17, 2013 | 11:13 AM
grbrown's Avatar
grbrown
Thumbs up
Great news - just occasionally a dealer does good!
coloradowoody
Feb 21, 2011 12:44 PM
champ198
Nov 10, 2010 06:42 PM
Archilochus
Jul 5, 2010 04:47 PM
Ky Windage
Jul 21, 2008 08:26 AM
ajdrr
Jul 2, 2008 10:28 AM
