PC-V Timing/Pinging question
Old May 16, 2013 | 09:15 AM
Hughey79's Avatar
Hughey79
Default PC-V Timing/Pinging question
As mentioned in other posts I had my bike dyno'd in Sturgis last year by Speeds. They did an excellent job correcting a lot of getting my bike more in tune. One thing that one of the brothers stated while he was doing it was that the idle was very lean.
When the bike it hot it would bog down in idle. I noticed in the timing section the 500 and 1000 rpm area it was advanced at 5. I decided to back it off to 0 and the idle problem is now fixed. However....
Yesterday it was warm here and I rode for quite some time in stop and go traffic. When leaving a stop sign/light quickly or a quick rap on the gas I could hear it ping just once or twice.
Now I am wondering should I put the 0's back up to maybe a 2 to give it a little more fuel timing at idle area.
Anyone have some ideas or shed some light on the subject? Also I do not have auto tune at this point and know it doesnt adjust timing even if I did. I also tried to search for answers first.
Thanks!
Old May 16, 2013 | 10:26 AM
mkguitar's Avatar
mkguitar
advancing ignition timing will make pre-ignition more likely.
Mike
Old May 16, 2013 | 10:30 AM
dyna07custom's Avatar
dyna07custom
usually retarding the timing will reduce ping
Old May 16, 2013 | 10:36 AM
Hughey79's Avatar
Hughey79
I would agree normally but since going to 0's I no longer smell the richness I had before at idle so it leads me to believe that is the issue. Also when speaking to DJ on the phone last year the tech kept wanting me to add timing up 10 in the column.
Old May 16, 2013 | 11:01 AM
mr396's Avatar
mr396
Yes, I do not have a PCV (I have a Thundermax). I would advance the timing just a couple degrees, test ride to see if still occurs, repeat if necessary. I know the timing at an idle on my bike is advanced to 10 deg at 500 rps and close to 20 by 1000 rpms.
Old May 16, 2013 | 11:13 AM
mr396's Avatar
mr396
can you enter negatives numbers in PC-V?
Old May 16, 2013 | 01:17 PM
TUCCI's Avatar
TUCCI
Yes you can. I put -1 in certain areas as well as -2 in the real tough ping trouble tables and my ping is all gone and that's what I suggest you do.
Old May 17, 2013 | 01:59 AM
ke5rbd's Avatar
ke5rbd
Thanks!
Could use more info. On cell doesn't show bike info. What year what model what engine exhaust intake mods. You don't need any additional timing in the 0 timing area. I would add about 5 to 8 fuel in the 2% to 40% throttle opening area from 750 to 2000 rpms. Unless the tune is showing above 5 degrees additional timing in the same area you problems are probably mixture related.
oldlefty
May 18, 2015 11:17 PM
Alias69
Jun 10, 2012 06:37 AM
louisianaSVT2001
Oct 31, 2011 06:53 AM
128auto
Jul 11, 2011 08:27 AM
glidenwide
Mar 26, 2011 05:33 PM
