Changing Out Handle Bar Grips
Old Jul 9, 2013 | 07:10 PM
GMRO's Avatar
GMRO
Default Changing Out Handle Bar Grips
So my 2006 EGUC has the black dull and worn factory handle bar grips.
Birthday is on the way and wife is getting me a new set of grips. Don't want heated grips. Something with chrome and black.
How difficult are they to change? I've done tires; brakes; shifter linkage upgrade and had the front faring apart to run my own iDevice cord; installed accent LEDS; battery and some other things.
So can I do this? Are there any tricks to removing the old grips and installing new ones? Will the push/pull throttle cable, EFI, be easy to adjust or it does not?
Thanks for any help/suggestions.
Old Jul 9, 2013 | 07:15 PM
Iceman24's Avatar
Iceman24
My bike's TBW, but grip swap's one of the easiest things to accomplish/upgrade. Left grip might have to be cut-off and on the Right (throttle) side - be VERY CAREFUL of the front brake switch (between lever & control cap. I put a small piece of plastic cut from old coffee can I set in recycling...use it as a "shim" to protect the switch.
Other than that - good luck!
Old Jul 9, 2013 | 07:18 PM
TUCCI's Avatar
TUCCI
If your used to wrenching it should be a snap. If the stock one's are glued (prob are) you will need to break the glue bond (left one only). If it wont let go you can run a thin screwdriver between the grip and handlebar slowly around till enough of the bond is broken so you can twist off the grip. I do not suggest you use any glue on the next set as that's 'ol school and unnecessary. Electrical tape wound around the bar (candy cane style) will be enough to hold it tight enough. The right one is done the reverse order of removal. You shouldn't have to adjust anything as your not changing any functionality of the grip just the grip itself.....hope this helps.
Old Jul 10, 2013 | 08:19 AM
GMRO's Avatar
GMRO
THANKS to both!!!
Old Jul 10, 2013 | 08:42 AM
gmc's Avatar
gmc
Right side is a little tricky on pre 08 throtle cables . It helps to loosen the throtle cable adjusters so you can get the throtle wire out of the groove. Be careful not to drop the little brass sleves that hold the wire on the grip. Also you should pull the brake handle and put a piece of cardboard in the slot to prevent breaking the switch button. Naturally you have to adjust your throtle cables, do the pull open side first making sure you get it wide open, then the return side just tight enough so it returns without binding.
Old Jul 26, 2013 | 08:01 PM
GMRO's Avatar
GMRO
Thanks!!! Did the upgrade and all worked super! Very happy with the new grips. And I lubed the throttle cables too.
Now onto a new windshield and some covers for the front axle nuts.
Birthdays are the greatest time for HD upgrades!!!
Old Aug 29, 2013 | 02:46 PM
GMRO's Avatar
GMRO
Nice to report...grips are super. Can really feel a difference on rides with the wider diameter vs. the small stock grips.
I trimmed the OEM windshield and it looks great at 9" vs. the 12" height. Now I can see over it fine and it still provides nice protection on the highway with no buffeting.
PLUS got this new cover for b-day week too. My old cover was showing it's age -was not HD type but it worked. WOW, this cover is nice quality and fits very well. Hope to get many years and great use out of it.
Attached Thumbnails Changing Out Handle Bar Grips-hd-cover-rs.jpg   Changing Out Handle Bar Grips-hd-cover-ls.jpg
Old Sep 5, 2013 | 12:20 PM
Inzane Inc's Avatar
Inzane Inc
Stage I
Default removing left grip
i bent my handle bar in a slide, had to remove the left grip. brute force in twisting didn't work, wasn't going to cut it off, and soap and water only cleaned it really nice.. "GOO GONE CLEANER" worked brilliantly, worked a lil in the grip between the bar and the grip, worked it in with some air from the compressor... twisted left, right, left and it popped off no problems... will never do it any other way again..cheers
Wranglin4Life
Mar 28, 2015 12:14 AM
larry harding
Aug 1, 2014 08:13 AM
HDF Tech
Sep 11, 2008 04:32 AM
LoRyder
May 24, 2007 06:16 PM
Hossman
May 15, 2006 02:17 AM
