2011 Problems
Old Jul 14, 2013 | 05:40 PM
hfdarson1's Avatar
hfdarson1
Default 2011 Problems
2011 Ultra 50,00 miles. While down shifting from 3rd to 2nd bike died rolled into a parking lot. Battery is original. Bike has power but the starter will not do anything. Bought new battery from auto parts and replaced it. Started bike up and it ran for a few minutes and died again. Finished replacing seat bike fired up and drove bike home 20 minutes no problems. Parked in drive and turned bike off and tried to start and battery dead again, Power but no starter movement at all. Waited 10 minutes and bike started like no problem at all. Anyone have a suggestion?
Jerry
Old Jul 14, 2013 | 05:44 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Jerry
Since you changed the battery, I assume both connectors are clean & tight?
No experience with your problem though, so I'll sit back and listen......
Old Jul 14, 2013 | 06:24 PM
TUCCI's Avatar
TUCCI
Check all the connectors you can get to for connectivity and water/moisture issues. Coat the connectors with dielectric grease.
Old Jul 14, 2013 | 06:26 PM
lp's Avatar
lp
Grounding and Voltage regulator... Places I would look.
lp
Old Jul 14, 2013 | 07:55 PM
12hdrk's Avatar
12hdrk
I would check the grounds. Sounds like bad/loose ground.
Old Jul 14, 2013 | 08:15 PM
1Canuck's Avatar
1Canuck
take a feed off battery to starter to see if it turns over that way to isolate problem
Danny8065
Jun 23, 2019 07:16 AM
braycarr
Electrical/Lighting/Alarm
Mar 26, 2016 10:00 PM
alvinator
Jul 6, 2014 11:21 AM
devoguy84
Jun 8, 2013 03:05 PM
Milwaukean
Apr 28, 2013 09:03 PM
