I have been noticing oil on top of my point cover( above it in on chrome) No idea where this is coming from. So below Air filter and just above point cover
Is it red? Maybe air filter oil Check the breather lines that run into the back of the air filter?
took off air filter .oil inside cover and inside air filter. Just washed air filter with dawn and some green degreaser. Could my dirty filter cause this oil issue
I have a high flow air filter. It will drip once the filter gets saturated from the breather tubes that drain down from the heads. It means that it is time for you to remove and clean the air filter.
