Cat removal
Old Jul 28, 2013 | 12:39 PM
screamer56's Avatar
screamer56
6th Gear
Default Cat removal
Was thinking about removing the cat from standard 2013 FHLTK headers. When Tig welding up hole on header anyone suggest what the rod should be.
Old Jul 28, 2013 | 01:16 PM
Cep10SG's Avatar
Cep10SG
This topic can be found using the search box, i've removed many Cat's and taken them to local shop to weld it back together. As long as the Welder knows what he's doing he'll know what rod to use and not burn/blow through anything, i'm no welder which is why i had someone else do it for me (you didn't mention if you were going to try to weld it?). My prefered welder uses a tig welder and since i always cut at the factory welds you wouldn't know it was cut open unless i told/showed you. Another Welder i used at the last minute used a mig welder. I hope this helps.
Old Jul 28, 2013 | 05:36 PM
rob0225's Avatar
rob0225
I just did mine but I drilled mine out. I am confident I got 99.9% of the material out. Took me about a 1 1/2 hours.
Old Jul 28, 2013 | 06:06 PM
Billyram's Avatar
Billyram
I believe the local shop uses a mild steel rod to tig weld the window back up and then ceramic paints the collector. I just drilled mine out.
Billy
Old Jul 28, 2013 | 06:13 PM
TSD's Avatar
TSD
What did you guys use to drill it out? I need to do my brothers 2013 roadglide, but would rather not cut and weld.
Old Jul 28, 2013 | 06:54 PM
TUCCI's Avatar
TUCCI
I cut open the front of it and carved it out like a pumpkin removing every bit of the honeycomb **** inside of it with whatever I had available to do the job. Don't do it half assed, if your not going to cut it open just leave it alone. Try to imagine carving out a pumpkin thru a 2" hole.....exactly.
Take it off the bike and put it on a bench vice before you carve it out or your going to hurt your bike....it's a big mess and you don't want your scoot anywhere near it when you go to town.
Old Jul 28, 2013 | 07:34 PM
firefighter616's Avatar
firefighter616
1 1/2 line at 125 psi will knock a cat out of a tree a good distance..
Old Jul 28, 2013 | 08:56 PM
rob0225's Avatar
rob0225
16" long 1" spade bit and a good drill.
Old Jul 28, 2013 | 11:12 PM
my67pnycar's Avatar
my67pnycar
Since nobody told you, Welcome to the forums Screamer. When you cut your cat out, cut along the length of the pipe in the oval big middle part of the pipe (thats where the cat is) cut a window out of 1/2 of that section, dig all the cat material out then clean with a flapper wheel or something, take it to a muffler shop and have them button it back up for less than 50 bucks, cheap DIY. Dont just cut the pipe in 1/2, you will loose length when you put it back together and things wont line back up. I am attaching the link for a thread that explains how to gut the cat DIY. If you do not feel like messing with it, you can get one already done from fleabay for round 100 shipped to your door, or google american customs, they do this also and they gut stock mufflers and have a link with pics and tools needed for exhaust removal and assembly. Also you can use the search feature on the top right by the advertising button under the fuel moto banner, type in what you want, click show threads hit go, whatever you are searching for will pop up. Hope this helps you out, stay safe out there..
https://www.hdforums.com/forum/touri...with-pics.html
http://www.americancustom.com/media/news/AmerCustom.pdf
Old Jul 29, 2013 | 05:49 AM
glide2005's Avatar
glide2005
If you cut it open with a 1/16 thick cutoff wheel.
I would use 3/32 mild stainless. That way, it the bead want rust up on ya.
