Help with Inner Fairing Brass threads
Old Aug 23, 2005 | 09:50 PM
Kess's Avatar
Kess
Default Help with Inner Fairing Brass threads
I'll try to be brief but need some suggestions - 05 EG Classic - Removed the wing to put on a set of fairing pouches - Went to put the wing back on and got distracted (long stupid story) and actually pulled out two of the brass inserts from the inner fairing while tightning them down - gently tapped them back on for now and got the end one tight enough but the one in the middle is not holding - Am I looking at replaceing the inner fairing or does anyone have any tips how I can get the brass inserts back in tight enough so they will hold? Hope I described it clearly enough
Old Aug 23, 2005 | 10:18 PM
pilot1996's Avatar
pilot1996
Default RE: Help with Inner Fairing Brass threads
Call your dealer, get new brass fittings...apparently this happens a lot. f13in/pounds in the future.
Mac
Old Aug 23, 2005 | 10:19 PM
HDF Tech's Avatar
HDF Tech
Maybe some epoxy glue or JB weld might do the job. Just keep it out of the threads.
Old Aug 23, 2005 | 10:38 PM
John TN's Avatar
John TN
Kess, do a search, I remember seeing a post on fixing the inserts, seems like it was Joe Scout, but I can't remember for sure. Good luck.
Old Aug 23, 2005 | 10:47 PM
Kess's Avatar
Kess
Thanks guys!- I did do a search but running the search including Joe Scout did the trick - JB Weld it is! - Got a 250 mile ride tomorrow - Hope the whole thing don't rattle off - LOL
Old Aug 23, 2005 | 10:55 PM
Antnee's Avatar
Antnee
4th Gear
Had this happen to my 05 Ultra. Harley makes a fix, the new ones screw into the inner fairing as oppossed to push in.... they repaired mine under warranty as it is pretty common
Old Aug 23, 2005 | 10:56 PM
luvmyflhtcui's Avatar
luvmyflhtcui
You'll have better luck with 2 part epoxy. It will dry clear and last for years. Ride on.
[IMG]local://upfiles/494/AAC38C6E4BA04186B33642861DCF396E.jpg[/IMG]
Old Aug 24, 2005 | 02:40 AM
mikeisglidn's Avatar
mikeisglidn
i hate those things! i used epoxy every thing good!!
Old Aug 24, 2005 | 11:30 AM
Blue SOG's Avatar
Blue SOG
Had this happen myself. Tried the 2 part "Plastic" adhesive... no good. Tried heating the brass insert then hammering it back in... no good (tried this 1st). Used JB Weld... still holding strong! JB Weld is the right way to go.
bbissell
2014-2024 Touring Models
11
Feb 15, 2022 11:37 AM
omgtkk
Apr 3, 2009 08:41 PM
Buster747
General Topics/Tech Tips
Jan 2, 2009 01:56 PM
ricaroo
Apr 17, 2007 11:50 AM
sportyrider1
Mar 13, 2007 07:12 PM
