Baffles gone...
Old Aug 11, 2013 | 11:04 PM
A Whole lotta Rosey's Avatar
A Whole lotta Rosey
Default Baffles gone...
Just removed the baffles from my V&H 4" rounds. Loud... yes. Actually very impressed so far.
Question - I know this reduced the back pressure and that corresponds a small decrease in power (doesn't seem like a lot so I'm ok with it - besides putting in new high torque cams soon). Anyway, I'm hearing that this reduction in back pressure will ruin my valves.
Does the reduction in back pressure hurt the valves?
Old Aug 11, 2013 | 11:17 PM
mkguitar's Avatar
mkguitar
I doubt you'd have any problem.
"valve problems", might be burned valves or seats, this is likely to happen if there is a leak at the head and oxygen can be drawn in and turn the exited gasses into a "cutting torch".
your exhaust tract should be long enough where that wouldn't be a problem.
you are likely to see substantial performance gains at 6000 rpms now
the "backpressure" is a real generality- more an issue is exhaust gas velocity- if the exhaust tract suddenly gets "larger" then the exhaust gasses will slow down and not exit as quickly.
there are all kinds of factors, length, diameter, rpm etc. etc. add in cam profile and it is more complicated than maybe any other part of the system.
mike
Cb1000h
Apr 18, 2020 09:36 AM
haak30
Feb 18, 2017 01:35 AM
Ronnie11
Jul 24, 2012 05:05 PM
Grog
Engine Mechanical Topics
Sep 15, 2011 08:32 PM
tmitchellof PG
Exhaust System Topics
Oct 29, 2006 03:11 PM
