Horn relay that flases head lights ??
Old Aug 15, 2013 | 11:53 AM
baust55's Avatar
baust55
Default Horn relay that flases head lights ??
A long time ago I saw a post about a safety product .
It was a horn relay that if you pushed the horn button once it would just honk the stock horn once. but if you held the button down it would start blasting a louder air horn mounted under the saddle bags and flashing the headlight and passing lights .
Does any one know the name of this product ? the manucatcurer Link ?
Also has anyone here used this product ?
Old Aug 15, 2013 | 12:21 PM
Shadowbennie's Avatar
Shadowbennie
It's called Screaming banshee. I had one on my vulcan nomad for a while, it seemed to work pretty well. I'm unsure if it will flash your passing lights unless they're running on the same wire as your headlight, but it does flash the headlight for sure.
For some reason mine kept blowing my horn fuse, but on my buddies street glide, it worked. His issue was finding a place to mount it, and his mounting bracketry kept breaking.
Old Aug 15, 2013 | 12:36 PM
baust55's Avatar
baust55
Thanks for the info ...COOL !
AUSTIN
Old Aug 15, 2013 | 01:23 PM
baust55's Avatar
baust55
I found there web site http://screaming-banshee.com/
Old Aug 15, 2013 | 10:27 PM
skratch's Avatar
skratch
seems like contradictory information to me. if you flash your lights at someone, they may take it as a sign that you are telling them to go, but at the same time you're beeping your horn at them....
Old Aug 20, 2013 | 09:27 AM
baust55's Avatar
baust55
Must be a local thing there Scratch here flashing lights means slow down pay attention ?
Old Aug 20, 2013 | 10:08 AM
jimsuver's Avatar
jimsuver
I like that! It should turn your spot lights on and off as it flashes the headlight, it works that way with the factory switch.
Old Aug 20, 2013 | 11:49 AM
Pelonz's Avatar
Pelonz
Here it means move over
Old Aug 20, 2013 | 12:40 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Why go through all that? Just install a good loud horn and be done with it. Maybe I'm missing something.
Old Aug 22, 2013 | 01:01 PM
baust55's Avatar
baust55
Ok I contacted there tech support guy Greg buy email with a few questions he called me right back on the phone and was very helpful.
He helped me pick out the system I wanted and sent me a paypal invoice, was real easy to order .
I selected the $10 option to upgrade to a walo horn as it has a heat shield that seems to make it a bit sturdier there basically the same horn .
I am planning on adding a longer wire . I will tie into stock horn mount the relay under the seat and mount the horn behind the saddle bag.
I bought a black horn, they also have chrome .
When I get it mounted I will try and post some install pics.
I think this is link that gets you a 10% if it still works .
http://screaming-banshee.com/?acc=c4...cc509a6f75849b
AUSTIN
dickey
Jul 20, 2019 11:53 AM
ronaldrwl
Sep 22, 2018 11:58 AM
brandss
Aug 30, 2013 01:03 PM
rebbe18
Aug 12, 2013 12:52 PM
Catmanjoe
Oct 26, 2012 10:15 AM
