crack on exhaust header
Old Aug 29, 2013 | 02:58 PM
tccraiger's Avatar
tccraiger
Default crack on exhaust header
noticed a small crack on the rear cylinder header of my '07 Road King... already ordered a true dual pipe from Fullsac, any reason in the meantime I shouldn't be riding?
Old Aug 29, 2013 | 03:03 PM
mkguitar's Avatar
mkguitar
this is common.
easy to weld but DO NOT weld with it on the bike ( blow the ecm).
just take it off, take it in.
this crack may cause damage to the exhaust valve/valve seat, so don't ride a bunch until it's fixed even if temporary like some kinda fix-it stuff from pepboys.
the Y pipe can be stressed and cracked by owners hammering on the mufflers when changing slip ons.
Mike
Old Aug 29, 2013 | 03:08 PM
kingomtn's Avatar
kingomtn
If you do band-aid it: remove heat shields in the area of the crack and drill a small hole >1/16", just past each end of the crack.
Old Aug 29, 2013 | 03:20 PM
big cahuna's Avatar
big cahuna
I've had 2 crack at the y joint, at the bottom of the rear pipe. I think they crack do to the shake from the rubber hanger mounts. The header pipes are solidly mounted but you can jiggle the mufflers. After a while something cracks.,,
Old Aug 29, 2013 | 03:51 PM
PNSHVL's Avatar
PNSHVL
Try JB weld until your new pipie gets here.
Old Aug 29, 2013 | 04:10 PM
tccraiger's Avatar
tccraiger
ok, thanks for the input guys, hopefully new pipe will be here in day or two so I'll just stay off the girl until then, she'll probably enjoy the rest.
Throttle1971
Nov 8, 2016 03:56 PM
99octane
Jun 4, 2015 08:34 AM
brianm73
Feb 22, 2011 02:06 PM
chiefparry
Nov 16, 2009 11:13 AM
SteveO
Jul 5, 2006 01:32 AM
