Cam Install Help
Old Sep 10, 2013 | 10:44 AM
UltraNutZ's Avatar
UltraNutZ
255 cams wouldn't be my choice either but realistically they are good cams.. you'll be happy with the bottom end they provide if you're not a power freak....
Old Sep 10, 2013 | 10:56 AM
rollin_thunder's Avatar
rollin_thunder
Originally Posted by UltraNutZ
another thing you want to do while you're in there is under the breather are 2 .060" oil drain holes. Drill those out to 1/8" and then taper the hole with a 1/4" bit.
Here's a pic of mine.
Ok, dumb question....but why???? Obviously better flow but this is the first time I have heard anyone doing this...and I've read and watch quite a few videos!
Old Sep 10, 2013 | 11:03 AM
UltraNutZ's Avatar
UltraNutZ
you know that seepage you get in your air-filters... well what this does is allows that oil to drain a little quicker out of the top end therefore less chance it will wind up in your breather. Certainly not something I'd pull my top end apart for but since you have it open, get-r-dun..
And I corrected the above post. I used an 1/8" bit to drill the holes and a 1/4" to round out the holes
Old Sep 10, 2013 | 12:04 PM
Bowhunter61's Avatar
Bowhunter61
+1 on this, if you are already getting in there just do it.
Old Sep 10, 2013 | 12:22 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Your taking a chance using the stock push rods. There will be no way to adjust any ticking or rattling sounds out in the event they occur. My advice, buy the SE Tapered Adjustables Pushrods and adjust them to 3 full turns. Plus with adjustable's, when you get tired of the SE255's, you can install any other cam and just readjust the pushrods.
I installed the SE255's and had nothing but trouble between engine noise and performance issues on my 96ci.
Installed the TW-222's and with my ECM adjusted, bikes runs great with probably less noise then when stock. I wish my MPG were a little better but I guess 40's not that bad.....
05dlx
2014-2024 Touring Models
13
May 27, 2015 07:25 PM
98hotrodfatboy
Engine Mechanical Topics
Mar 17, 2015 06:14 AM
hddave2
Jun 10, 2009 03:56 PM
G wood Todd
Exhaust System Topics
13
Aug 21, 2007 08:14 PM
MiniMe
Jul 28, 2007 10:46 AM
