Heal Shift Removal.. Hacksawed Shifter Shaft..
Old Oct 13, 2013 | 07:54 PM
  #71
goldie's Avatar
goldie
Hi all,
I had put a breather line off my SE AC and bought a 1/2 OD 3/8 ID rubber plugs. Came in a two pack at Napa so when I read the first few posts I went and tried it. A smidge long so trim it 1/8" and she looks good and isn't going to come off based on how hard it was to slid off. Thanks for the idea..........goldie
Old Oct 14, 2013 | 04:57 AM
  #72
motolocopat's Avatar
motolocopat
I can't believe I read through all of this thread
At least I have the lame excuse of being stuck in the Outback of Australia trying to kill time....
Off all the options here for this simplest of tasks I think the best one was they guy who put some cheap crap on and it bothered his riding buddies so he left it on ...... Think that is the one I'll go for
Old Oct 14, 2013 | 08:14 PM
  #73
SequiMike's Avatar
SequiMike
Originally Posted by Ken Oaff
I'm not shaft is splined at both ends, double the splining on the heal toe end, if you cut one of these splines off and fit the shaft back to front the cut end is next to the motor
Sounds like you have a different shaft than I do. Mine is splined on one end, but has the transmission rod arm welded to the other end.
Old Oct 15, 2013 | 09:22 AM
  #74
Leftcoaster's Avatar
Leftcoaster
The Heritage shifter shaft is different from the touring shaft. You can still do the same 'cut down' mod but replacing it is a bit more costly at around $40 should you decide to go back to the heel/toe arrangement.
Old Oct 16, 2013 | 04:32 AM
  #75
SoftailBrian's Avatar
SoftailBrian
I just turn the heel shifter to where it's sticking straight up and call it a jockey shift.
e11charlie
Jul 2, 2020 06:48 AM
UltraClassicWNY
Oct 11, 2015 05:49 AM
bobby5
Sep 25, 2013 03:08 PM
Big Blue
Sep 6, 2009 06:49 AM
jm1211
Feb 2, 2009 10:45 AM
