Security Key Light On
Old Sep 30, 2013 | 10:25 AM
CurtisO's Avatar
CurtisO
Default Security Key Light On
Looking for a little help. The security system light- the little key- lights up intermittently while riding. And the turn signal indicators on the dash will light with the key light. If I flash the turn signal they go away for a while. While parked the security seems to work right, just flashes. And it resets when I turn the bike off. New battery in fob. What to check?
Old Sep 30, 2013 | 10:36 AM
Bingee's Avatar
Bingee
You might want to check under your seat to make sure the TSSM is securely plugged into the antenna module and nothing is out of line there. Maybe clean off the connector contacts as well. Could be your TSSM is going bad. But that's a long shot.
Old Sep 30, 2013 | 10:56 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Check your codes, the light stays on when there are codes present...
Old Sep 30, 2013 | 11:05 AM
CurtisO's Avatar
CurtisO
I didn't think to check for codes. I'll check codes and connections tonight. I did change the battery last week. The TSSM got moved around. Thanks.
j09789
Jun 16, 2020 04:48 PM
Sailrider 1
VRSC Models
Oct 8, 2014 06:32 PM
fatguy-littlebike
May 28, 2012 02:02 PM
pbsdaddy
Feb 23, 2011 08:01 PM
ko4qc
Jun 16, 2009 12:28 AM
