Bagger wobble solved!
Old Dec 29, 2013 | 11:21 AM
  #71
fabrik8r's Avatar
fabrik8r
Originally Posted by Imold
Maybe I missed it, but don't see in this thread how you folks are coming up with the alternate bearing numbers - do the companies mentioned know what you need?
Refurbishing my old Tour Glide this winter, and swing arm is on the list, but it doesn't have spherical bearings anyway. I replaced the spherical bearings in my 04 sportster this past summer, were so tight with the wheel and shock off, had to push the swing arm down. Bearings were lined with crud; cleaned off, looked ok, but had noticeable side play. Couldn't find aftermarket replacements, so got the German made ones from Harley, and they had almost as much side play as the old ones. Bike handles fine, but if I could find a tighter replacement, would put them on next tire change.
Dry spherical bearings with no seal seems to be a poor choice in such an exposed area. I covered up the exposed sides with red tacky grease, but that won't keep crud out forever. I've used spherical bearings with seals in aircraft; it can be done.
Take any bearing number to any bearing supply house, they can cross reference it for you. Take the old bearing with you, in the rare event they cannot cross reference it, they can physically measure it and find you a suitable replacement. With the internet available you may be able to cross reference it yourself at bearing manufacturers sites.
Old Dec 29, 2013 | 11:35 AM
  #72
Trek's Avatar
Trek
I've 50k on my 2010 ultra. It rides much truer better than my 08. I guess I'm wondering if this bearing upgrade would make the 10 an even better ride?
Old Dec 29, 2013 | 11:49 AM
  #73
2heritagespringers's Avatar
2heritagespringers
subscribed
Old Dec 29, 2013 | 11:50 AM
  #74
Senorjeem's Avatar
Senorjeem
5th Gear
All great info, and this is no doubt one of the causes for bagger wobble, but I would wonder if it is the holy grail. I was on a tour for a week on a new 14 Ultra and it had the wobble. Perhaps it is an installation issue with the bearings, if the depth is critical, but I had also heard people reporting some success with adjusting the bearing preload in the steering head bearings. Just saying, the 2014 that I was on would have had basically zero wear on the swingarm bearings and it wobbled real good once you initiated it.
Old Dec 29, 2013 | 12:04 PM
  #75
qtrracer's Avatar
qtrracer
This is getting funny, everybody "upgrading" bearings, LOL. If you read the op's post he says to check to see if you have play, if you don't, the bearings are not contributing to any instability.
Old Dec 31, 2013 | 02:18 PM
  #76
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Just finished pulling my 04 Road King swing arm assembly off chasing similar wheel play. About 1/8" deflection at the axle, with sharp clanks at the ends of the play. I was expecting worn bearings, but wanted to check before I ordered parts.
What I found was the bearing inserts (PN 48489-02) to be loose on the shaft, presumably worn. The bearings themselves were stiff and effectively frozen with dried grease. The swing arm was rotating on the inserts, not the bearings.
Cleaned the bearings, and they feel fine. ~$6 for replacement bearing inserts, and I should be good to go. Not saying it will be this way for everyone, but it's worth checking things before you order replacement parts.
Old Dec 31, 2013 | 03:14 PM
  #77
Imold's Avatar
Imold
Dried grease is so common I often clean out new bearings and re-grease them before use. Really good and not so expensive synthetic base greases have been available for a long time, but the old clay based grease that dries out doesn't seem to go away. I've pulled bearings several years old properly packed with synthetic that still had the same consistency as new. Some of the really good stuff is expensive (I've used $35 a tube grease), but for wheel bearings and swing arms, even a pound goes a long way for one or two bikes.
Old Dec 31, 2013 | 05:11 PM
  #78
luisan's Avatar
luisan
Originally Posted by fabrik8r
If you call Aroura they can provide you a distributor contact close to you, I try to spend local whenever I can. Bearing, Belt and Chain, Motion Industries in Phoenix is where I ordered them. I strongly recommend the Sta-Bo bushings to anyone, they work, If you still have a wobble after installing them, you likely have some other problem that a "third link" will just mask or not fix. I'm not going to claim you can remove your existing "third link" device after installing new swing arm bearings and Sta-Bo bushings, but I didn't feel I needed one. Its been several years since I installed the Sta-Bo bushings and now the rear is starting to feel a little squirrelly , I suspect the spherical bearings, and theses will probably work great.
Fabrik8r,as per your advice,I had the Sta-Bo installed on my '06 Ultra but I kept the Progressive brace that I had previously installed.I've never experienced the infamous "wobble" but I did the upgrade anyway as a sort of prevention.Do you think that the two (Sta-Bo & brace) could cause any unwanted effect or it's just overkill?Thanks and happy new year.
Old Dec 31, 2013 | 06:09 PM
  #79
fabrik8r's Avatar
fabrik8r
Sorry I can't speak from personal experience on that combo, but I don't think it will cause any serious problem. I believe the concern with using two different "stabilizer" products is vibration, but if its not translating extra vibration to the chassis, go for it.
Old Jan 4, 2014 | 02:17 PM
  #80
woodman's Avatar
woodman
Question fabrik8r
I have 75K on my 06 RKing and have replaced the front mount and have alot of vibration in bike. So when replacing the bearings do the sta-bos replace the rubber bushings? I hope rebuilding the swingarm will enhance the ride and eliminate some vibration. Any thoughts?
