Question about my Aux Toggle
Old Jan 5, 2014 | 08:54 PM
rsarno's Avatar
rsarno
Default Question about my Aux Toggle
On my 14 RK i have a toggle on left which controls my lower fog set. Then another toggle on the right which is dead, im assuming i can use it for anything...
Is this wired to function as the other toggle, where the power is killed when i shut the key?
Also where are the terminals for this switch, or do i need to run my own wires/fuses?
thanks
Old Jan 5, 2014 | 09:00 PM
hanny's Avatar
hanny
if you got a picture that might help,,, probably a plug in , in the hareness for ya
Old Jan 5, 2014 | 09:16 PM
FDHOG's Avatar
FDHOG
I forget exactly which wires they are, but behind the headlight you can access the switch wiring. I use it to control the power to my GPS when I have it mounted. The switch is only active when the ignition is on. If you have a shop manual, you can locate the proper wires.
Old Jan 6, 2014 | 12:17 AM
mkguitar's Avatar
mkguitar
for the past 20 years, the aux plug has been under the seat, in front of the battery.
maybe that changed for 14, but I doubt it.
the owners manual should be pretty good source of info on this.
I earlier today posted a pin out for the 09 model, could be the same for yours
Mike
Old Jan 6, 2014 | 01:54 AM
evill1's Avatar
evill1
Yeah, typically under the seat for rider accessories
Old Jan 6, 2014 | 02:32 AM
ghostrunner's Avatar
ghostrunner
The plug is under the seat and is switched with the ignition switch. Here is a link to a harness to use for connecting to this switch for your accessories. Hope this helps.
https://www.pmlightglide.com/product.html
Old Jan 9, 2014 | 08:42 AM
HarleyQC's Avatar
HarleyQC
Look at your owner's manual page 63-64, the right side switch is connected to a accessory plug under the left side cover.
oldsoldier181
May 21, 2018 03:20 PM
Ultra Pearl
Feb 22, 2018 11:10 AM
sbeast
Jun 22, 2015 07:30 PM
Pyrotag
Apr 17, 2014 12:56 AM
Edmo
Jul 4, 2006 03:55 PM
