Idle question
Old Jan 31, 2014 | 11:51 AM
Arizona Sage's Avatar
Arizona Sage
Default Idle question
I have a 2007 RK with 26,000 mi. I ride it to and from work just about every day. In the mornings when I start the bike, it idles just fine. In the afternoon when I start the bike to come home, the idle is noticeably high for a while. Is this possibly due to atmospheric conditions? I honestly have no idea what to make of it. Anyone have similar experiences and know of solutions?
Old Jan 31, 2014 | 12:03 PM
SmokeyJoe101's Avatar
SmokeyJoe101
Could be a difference in temps.... But I would check for vacuum leaks, intake manifold gaskets and clean sensors.
Old Jan 31, 2014 | 12:09 PM
jdvorchak's Avatar
jdvorchak
Is it warmer in the garage in the morning when you leave for work than when you go home? I think the 07 is EFI and idle speed is governed by cylinder head temp. Colder = high idle longer. This sounds normal to me.
Old Jan 31, 2014 | 12:10 PM
ynots's Avatar
ynots
How long does it take for the idle to drop down? On cooler mornings my bike will idle faster for about a minute. I assume its the efi working as a choke? When I had a heated garage I never noticed it
Old Jan 31, 2014 | 02:52 PM
Arizona Sage
It drops to normal within a few minutes. Yes, it's EFI. I store it in a garage which is basically room temp overnight. By the afternoon it's usually a bit warmer (being in the Phoenix area). Thank you guys for your insight.
Old Jan 31, 2014 | 03:05 PM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
EFI does run a high idle routine based on cylinder head temp. The colder it is, the longer the high idle. How high are we talking? 1,500 RPM or less is normal.
Old Jan 31, 2014 | 03:14 PM
Arizona Sage
Not sure how high it actually is as I don't have an rpm meter but it's noticeably higher to the point where if I put it in gear there's no need to rev the throttle at all to get going. Just letting the clutch out gets me going, although that drops the idle slightly. More inclined to start and wait a few minutes until it warms up a bit. I will have this checked when I hit up my mech for tires soon.
Old Jan 31, 2014 | 03:28 PM
jdvorchak's Avatar
jdvorchak
I like that dyna in you sig. One big regret is that I got rid of my dyna fxdx. I will get another!
Old Jan 31, 2014 | 03:38 PM
spider14043's Avatar
spider14043
Your idle air control needs to be cleaned. There are threads on this. The sensor is located inside the throttle body.
Old Jan 31, 2014 | 10:55 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
07 has a some erratic idol problems iac and tps most common,temp sensor is another.
Dazzauk
EVO
21
Sep 6, 2016 12:01 AM
Silvertrain1025
Mar 2, 2013 09:31 AM
EVOrider
Aug 25, 2009 04:23 PM
Sketz
Feb 19, 2009 07:40 PM
Win_Brad
Mar 15, 2008 10:42 PM
