Audio Issues, Upgrade available?
If you really wanted to spend a lot of that hard earned money you could just replace the Harley amp and speakers with after market and your would be blown away. Go a step more and change out the head unit as well and you have some more tuning options. Your CVO is a 1 ohm system, if your going to upgrade try to think of what you want to end result to be before you start buying stuff here and there. If you stick with upgraded amps and speakers instead of Harley stuff you can go to either a 2 ohm or 4 ohm speaker and amp set up, which the best part of doing this is it opens up a larger range of options of what you can add and types of equipment you can use.
I went to a pro audio shop yesterday, he cranked up some bikes he just replaced everything, including the head unit, and it wasn't as loud as what I have. :/ He's trying to sell me on Big Ultra Hog Tunes, but that is (1) 160 watt (4) channel amp, pushing 40 watt per channel. My currently setup is (1) 160 watt (2) channel amp, pushing 80 watt per channel, which most likely is daisy chained through the 4 front speakers and has the (1) xxx watt amp in the back that has no specs anywhere, so not sure what that is. However all speakers have very small coils where the Big Ultras are much larger. Not sure that is worth the money to upgrade too.
