Replacements lamps
Old Mar 14, 2014 | 11:45 PM
kew48's Avatar
kew48
1st Gear
OK--Update- My appologies to some of the folks who responded about the Main Headlight being a capsule type with H4 bulb. After removing it, it is an H4 type. Now just need to clean the lens with vinegar as suggested. The spots are sealed- Candlepower does make a Wagner #4449 version but be aware that the circumference is a tad bit smaller than the Wagner. You can make it work however with a little work.--Thanks for all the responses--
Old Mar 15, 2014 | 09:53 AM
Punjabi Rider's Avatar
Punjabi Rider
Originally Posted by kew48
Hello- New to the forum-- 2002 Roadking-pretty much stock with lots of chrome- Can someone tell me the replacement parts for the headlight and the front passing lamp?-- I have one passing lamp out and the headlight has developed some kind of a fog on the inside. These are sealed beam lamps. I think the oem lamps are Bosch. Perhaps someone knows of a good quality replacment lamp too and a resonable place to purchase. Thanks for your help!!
Look at www.socalmotogear.com they have very sharp lights and save you crap load of money compare to Harley LED which are weaker when compare to any HID Bi xenon lights on the market.
Old Mar 15, 2014 | 10:47 AM
Uncle Larry's Avatar
Uncle Larry
No such thing as a dumb question ... How else could/would you find out? Good Luck with the lights.
Old Mar 15, 2014 | 11:28 AM
bigheadted's Avatar
bigheadted
Uncle Larry That is a right on reply !
Old Mar 21, 2014 | 12:06 AM
kew48's Avatar
kew48
1st Gear
Default 02 flhr
We'll I believe I've had it with finding replacements for the sealed beam spots. Can someone give the the Harley part number for the spot/running light kit to replace the original stock sealed beam lights to units that will allow the use of the replaceble H3 hallogen bulbs?--Thanks
Napalm Dog
Mar 12, 2014 05:57 PM
MidnightFLHX11
Jan 31, 2012 06:58 AM
fatboyNick
Aug 31, 2010 11:54 PM
yoseppi
Apr 26, 2009 09:54 AM
JBA111
Aug 19, 2006 01:48 PM
