Rattle,Knock
Old Mar 25, 2014 | 10:24 AM
berndog's Avatar
berndog
Default Rattle,Knock
Ok,I changed out compensator spring pack and bolt,torqued to 165,,still has a terrible hammering sound,,for some reason my friend is convinced its in the primary,as I have put on over 10,000km on it with this noise,,I'm trying to eliminate everything else before I braek into motor,as it dpesnt smoke or lose oil,,and no loss of power ,it run s great,,,But the hammering noise is annoying as hell,,any ideas.
Old Mar 25, 2014 | 04:57 PM
0ldhippie's Avatar
0ldhippie
If ya only changed the spring pak, ya still got a wore out compensator.
Old Mar 28, 2014 | 08:59 AM
berndog's Avatar
berndog
So I also chnged front motor mount,louder . Yesterday I rained engine oil after 200 km on fresh oil,,drain plug was covered in metal shavings.
Old Mar 28, 2014 | 10:42 AM
Turbo Turtle's Avatar
Turbo Turtle
. I'd get that checked out asap
BOB
Old Mar 28, 2014 | 11:18 AM
usraptor's Avatar
usraptor
There is something definitely wrong in the engine then. Get it checked out asap. Good luck.
Old Mar 28, 2014 | 01:00 PM
TUCCI's Avatar
TUCCI
Your likely getting ready for a major engine failure if you dont have it checked out....
Old Apr 2, 2014 | 03:16 PM
berndog's Avatar
berndog
So,I pulled the cam chest open,,no shavings in there,,both shoes are still there,,however wear on inside one is approx 80% front about 60%,,need replacing,But for some reason I still dont believe this is what is causing the rattle or Metal shavings
Old Apr 2, 2014 | 10:22 PM
berndog's Avatar
berndog
So does anyone know of rattling coming from brken or worn cam chain tensioner shoes?
Old Apr 3, 2014 | 07:34 AM
Veekness's Avatar
Veekness
The major engine damage has already occurred. Time to blow the engine apart and take a peek. If you don't know what you're doin'...don't.
Old Apr 3, 2014 | 08:09 AM
berndog's Avatar
berndog
I dont understand how there can be engine damage,and it runs great,,unless its just waiting to explode.
