Cam Installation help for a first timer.
Old Mar 30, 2014 | 06:56 AM
  #41
mirrmu's Avatar
mirrmu
Hi,
Thanks for reply
Mirrmu
Old Mar 30, 2014 | 09:04 AM
  #42
OldFordTrk1's Avatar
OldFordTrk1
Originally Posted by mirrmu
hi,
can clean engine oil be used instead of assembly lube?
thanks
mirrmu
I would say yes but before starting the engine, with the plugs out and the bike in high gear rotate the engine over manually to make sure the engine pistion and valves and not making contact. Then pull the fuse on the fuel pump, put in neutral and use the starter to turn the engine over until it builds oil pressure.
Old Mar 31, 2014 | 02:02 AM
  #43
mirrmu's Avatar
mirrmu
Hi,
Thanks for the info, i get some assembly lube
Mirrmu
atrain68
Jul 16, 2014 07:21 PM
BJFLHT
Apr 10, 2012 07:36 AM
skully1200
Exhaust System Topics
Nov 26, 2011 04:30 PM
aktid35
Feb 16, 2011 03:51 PM
Akitakoi
Aug 23, 2006 09:04 PM
