01 88 to 07 96 complete swap?
Old Mar 29, 2014 | 04:52 PM
son7771's Avatar
son7771
Default 01 88 to 07 96 complete swap?
01 electraglide efi Ok its been a while since I posted as my bike has been pretty reliable. Its now in need of some serious overhauling. I found a salvaged (no tittle) 07 touring with low miles and at a reasonable price. Will the motor tranny and swingarm all swap to my 01. I will have all wires and switches from other bike as well. thanks I have done lots of work on it to make it look new now I want to try a transplant as I can get salvaged bike cheap and sell other parts I don't need and come out ahead or break even.
Attached Thumbnails 01 88 to 07 96 complete swap?-989804_655564577791508_1110781310_o-1-.jpg   01 88 to 07 96 complete swap?-979566_655564427791523_62835054_n-1-.jpg   01 88 to 07 96 complete swap?-975084_655564524458180_1804489869_n-1-.jpg   01 88 to 07 96 complete swap?-963096_647013345313298_1623890361_o-1-.jpg
Old Mar 30, 2014 | 06:54 AM
son7771's Avatar
son7771
I may have posted this in wrong spot so if I did can it be moved?
Old Mar 30, 2014 | 10:16 AM
0ldhippie's Avatar
0ldhippie
Pretty sure a 96" 6speed will not bolt into a 88" frame. But don't know what would be involved??
Old Mar 30, 2014 | 10:24 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the frames are the same (the 02 newer has a larger swing arm) motor mounts i think are different,may require some cutting and welding the tabs.
Old Mar 30, 2014 | 10:36 AM
Northbound Southerner's Avatar
No way would I swap my 01 motor (probably the best twin cam ever made) for an 07...Build your 01 if it's getting tired...Your 01 has a MUCH better bottom end...
Old Mar 30, 2014 | 12:00 PM
jeg1's Avatar
jeg1
Totally agree
Old Mar 30, 2014 | 12:20 PM
Veekness's Avatar
Veekness
If you do make this swap...and I'd agree with the folks suggesting working over the original 88...don't forget to check with your state's DMV first to make certain you don't run into any title problems. I'd take the money that I would spend buying the 2007 and go to gear drive (if possible), new lifters, cams, and adjustable pushrods, and refresh the heads. Were it me, I doubt that I'd increase the CID, but that's just me. I suspect you'll spend less money and have less headaches going this route.
Old Apr 1, 2014 | 01:34 AM
son7771's Avatar
son7771
You guys are right I will stick with my motor. I will begin teardown in a couple weeks!
Ryan Payn
Jun 26, 2019 05:24 PM
jakas66
General Topics/Tech Tips
Mar 15, 2016 04:40 AM
AMathis
Jun 20, 2014 10:06 AM
SPFRUSCIONE
May 12, 2011 03:45 PM
Rancid33
Screamin Eagle CVO Models
Dec 25, 2009 10:46 PM
