MGS Duals install
Old Apr 10, 2014 | 11:16 PM
BamaBoyjc's Avatar
BamaBoyjc
Default MGS Duals install
Those that have installed these before or even those with a set...advice needed. I spoke to Mike when I ordered the set and he said put the O2 sensors closer to the head for a better reading when tuning...makes perfect sense. Problem is, on my 2012 RK the cable for the front cylinder is too short and I don't see how it will reach w/o an extension. Anyone been through Thisbe have seen it installed this way and know a solution. I'm gonna call Mike in am about it but was wondering if any help from you all tonight so I can maybe finish the install tonight. Any other helpful info is appreciated
Before anyone spouts out the usual "Search function is great" or the usual uneducated but just want to comment bs, I have searched multiple threads and the only info is for the rear cylinder sensor harness. At least that's all I could find through searching within the forum, as well as, through Google search.
Old Apr 11, 2014 | 12:28 AM
BamaBoyjc's Avatar
BamaBoyjc
Nevermind...I'm going to have to use the rear port and plug the front one. I'm an idiot and didn't pay attention to a key factor
Old Apr 11, 2014 | 11:06 AM
Billman812's Avatar
Billman812
Glad you got it figured out! I recently installed mine and I really like them. Exhaust note and finish is great. One note is to keep an eye on the clamps for the heat shields, I have had several loosen and a couple break. I guess they have also had some of the hose clamp tabs built into the shields break loose but not on mine.
Northbound Southerner
Dec 1, 2013 07:28 AM
Tee&Vee
EVO
Jun 9, 2013 08:02 PM
blueridge
Apr 7, 2013 07:32 AM
oldman1004
Apr 22, 2008 08:12 PM
SG 1
Aug 27, 2007 07:44 AM
