FLH headlight connector
Old Apr 15, 2014 | 04:30 PM
Timex's Avatar
Timex
Default FLH headlight connector
I replaced my headlight connector today on my 06 FLHX. the replacement has a black, a yellow and 2 white leads. The original only had one white wire. What does the white wire go to? Hot? I forgot to check with my volt meter bfore I buttoned the bike back up. Any ideas? Thanks....
Old Apr 15, 2014 | 04:40 PM
mkguitar's Avatar
mkguitar
std H-D wiring is black ground
yellow low beam
white high beam
there is also usually attached to the headlight loom wiring for a euro position light
black is ground, orange/white stripe is hot
many of us use this for GPS, phone charger etc etc.
mike
Old Apr 15, 2014 | 05:08 PM
Timex's Avatar
Timex
Thanks Mike. Why did the replacement have 2 white leads?
Old Apr 15, 2014 | 05:42 PM
mkguitar's Avatar
mkguitar
No Idea.
when I have replaced headlight plugs, i have used high temp from auto parts store.
Mike
Old Apr 15, 2014 | 05:48 PM
Timex's Avatar
Timex
Originally Posted by mkguitar
No Idea.
Mike
I should have gone to an auto parts store, not HD. Duh! Plug and 1 bulb (oem) cost around 29 dollars. Note to self: Don't work on scoot until I have "finished" my first cup of coffee in the morning. And skip HD unless absolutely necessary. All put back together and test rode before the rain set in. All good. Thanks for the input.
Old Apr 16, 2014 | 08:41 PM
Pyrotag's Avatar
Pyrotag
Is the orange and white wire a switched wire to the Aux switch?
Old Apr 16, 2014 | 08:52 PM
vzts4q's Avatar
vzts4q
No!
The aux switch controls a 4 pin Deutsch connector that is under the gas tank in front of the battery on pre 14 touring bikes.
the plug components can bee seen here.
http://www.deutschconnector.com/prod...ay_connectors/
Old Apr 16, 2014 | 09:31 PM
mkguitar's Avatar
mkguitar
nope, comes on when the ign is on.
mike
georgelemos
Nov 22, 2015 01:48 PM
motochick0218
Dec 20, 2014 05:08 PM
Stick_Drifter
EVO
Jul 18, 2013 06:17 AM
jcmer22
May 13, 2009 06:54 PM
Pipeman
Jan 20, 2009 11:37 AM
