Looks like I have to replace my clutch pack after 60000 miles on my 05 Ultra. For those that have done it, did you stick with the MoCo stock or did you go aftermarket? If you went aftermarket, what brand?
I haven't had to replace mine yet at 53,000 miles but if and when I do I'll probably go with Barnett. Ran them on my old Limeys and they were bullet proof.
Thanks for the input.
I'm in the same boat with my 05...I went with the Barnett.
I also have an '05 Ultra and went with the Barnett. They seem to be the best value for the money and I use them in my dirt bikes as well. I also agree with MKGuitar about replacing the steels at the same time. I would also recommend upgrading to the Screaming Eagle diaphragm if you've done any major mods.
I actually used the SE plus one kit. Got it from one of the 20% dealers, probably Zanotti at the time. So far so good with a 107" motor but you can't go wrong with Barnett either.
