Headlight will not aim
Old May 3, 2014 | 09:39 PM
dburgjohn's Avatar
dburgjohn
Default Headlight will not aim
The headlight on my 04 Road King will not aim. I have pulled in so far down that the low beam is useless and the high beam is still up in the trees. Bad bulb? Lens?
Old May 3, 2014 | 10:49 PM
mkguitar's Avatar
mkguitar
could be bad bulb- you have a standard H4/ 9003 ? type
2.) stock or do you have an "E Code" lens- Euro spec?
Europeans usually run the low beam quite close top the vehicle- generally lower road speeds in the city-
mike
Old May 4, 2014 | 01:30 AM
smithbrl's Avatar
smithbrl
I found the stock head light to be almost as useless as the air temp gauge. The high beam was only good for lighting up street signs. I switched to the HD LED headlight and have found much better results. There is minimal separation between Hi and Lo beam.
The stock headlight has two advantages
1) I could see the road as I went around a curve much better
2) It don't cost nowhere near as much as the LED headlight
Old May 4, 2014 | 08:26 AM
dburgjohn's Avatar
dburgjohn
The bulb in bike has the following number: OSRAM HB2 DOT 9003 L Germany Bilux 12v 60/55 w H4 U 37R (E1) 00801 w3z6. Is this the wrong bulb/lens?
Old May 4, 2014 | 08:28 AM
Juan L's Avatar
Juan L
Moderator
Is it in right side up?
Old May 4, 2014 | 11:06 AM
mkguitar's Avatar
mkguitar
that should be correct.
but the filaments may be out of whack.
the bulb cannot be upside down, it only goes in one way, make sure that there is not material in the grooves that index the bulb.
what headlight housing do you have ?
mike
Old May 4, 2014 | 12:44 PM
mwegryn's Avatar
mwegryn
Sounds like either a bulb defect, or it's not seating correctly on the back of the housing. Try swapping with another bulb if you have one and haven't already.
Old May 4, 2014 | 12:58 PM
bagman1's Avatar
bagman1
Agree! Id look and make sure all the tabs are in the right slots, then try another bulb, than maybe you may have to shim the bulb housing up or down in the nacelle to get an adjustment.
Old May 4, 2014 | 01:28 PM
dburgjohn's Avatar
dburgjohn
Default angle
it is the distance between low and high that is off. when low is set, high in the tree tops
Old May 4, 2014 | 01:34 PM
mkguitar's Avatar
mkguitar
yes, and that is what we are looking at.
each of the 2 filaments ( 1 for low, 1 for high) needs to be correctly aligned with the reflector to project properly.
so that is why we are asking if the bulb is in properly forward/backwards as that would take the filaments "out of focus" with the reflector/lens.
or a bulb if which a filament has shifted can do same.
follow?
for the 3rd time, do you have the stock headlight housing?
mike
