Another SE comp going, 2014 type.
Old Jun 1, 2014 | 11:04 AM
  #51
Smokey Stover's Avatar
Smokey Stover
Originally Posted by Streetrunner
I just picked up a 2010 eG Classic with only 500 miles on the odometer. Guess what, every start I get the WHACK! I cringe. The previous owner said it did it from day one and the dealer told him it was normal just to ride it. I'm thinking I should get the ESP on this bike. Should I put some miles on this thing like the dealer says?
Actually the cost of the 2 year ESP was more than enough to do a couple of Comps and then some! Don't even want to know how much 2 more years would cost on a four year old bike.
Old Jul 4, 2014 | 11:44 AM
  #52
Smokey Stover
Update, got the shifter seal and new 14 "A" version comp covered by ESP, didn't like the idea of glue and plastic inside the cover, I would be riding with my head cocked listening for it to let loose and grind up. Lol as well as wondering how long this comp will last. Since I was covered by ESP I went ahead and got the new o/p cover, compensaver and Hayden tensioner. Ready to button it all back up and go for a nice long test ride. I'll let y'all know how it holds up in 500 miles,when I check the wear in on the Hayden.
Old Jul 4, 2014 | 11:52 AM
  #53
soft 02's Avatar
soft 02
Coming soon is a fiber/plastic thrust washer to replace the roller bearing in the 2014 comp.
Old Jul 4, 2014 | 01:34 PM
  #54
Smokey Stover
Thanks, soft 02. I'll pick one up to have on hand when they''re released. I'll be opening it up at 500, 1000 and 2000 miles anyway. I guess I should look for a sale on fluids.
Old Jul 4, 2014 | 07:24 PM
  #55
karbar99's Avatar
karbar99
Default Primary Chain with Comp replacement
Just a quick question as I'm getting ready to replace my comp with the latest A version.
I've decided to replace the chain as well on my 09 with 65k. I've had the primary cover off before and ground the inner primary front lower lip to remove and replace the comp.
Question: Will I be able to remove and replace the primary chain without removing the clutch housing?
From looking at a few pics here looks like it will be close towards the rear side of the inner primary housing.
Old Jul 4, 2014 | 08:05 PM
  #56
soft 02's Avatar
soft 02
Gotta pull the comp and clutch to do the chain.
Old Jul 4, 2014 | 08:11 PM
  #57
karbar99's Avatar
karbar99
Many say when replacing the the comp (have to remove the comp, adjuster and clutch to replace the comp) but I didn't have to remove the clutch to remove the comp as there was enough slack in the chain after removing the adjuster.
Was just curious looking at some of the pics if there was just enough room between the clutch sprocket and the primary housing to finish removing the chain after the comp has been removed.
This part I cant remember when I had mine apart.
Old Jul 4, 2014 | 08:46 PM
  #58
MikeTD3's Avatar
MikeTD3
I just did one yesterday and you do NOT need to remove the clutch to get the chain off.
Old Jul 4, 2014 | 09:05 PM
  #59
Sailrider 1's Avatar
Sailrider 1
Originally Posted by Weavr99FLHT
Me... 40k on stock
40K on my SE comp with no problems
25K on my wife's 03 Road King with stock comp no problems.
Old Jul 4, 2014 | 09:07 PM
  #60
karbar99's Avatar
karbar99
Thanks!
That's what I was hopeing to hear.
