Heavy Breather Blow Back
Old May 20, 2014 | 09:45 PM
  #31
longhaul42's Avatar
longhaul42
My103 ac has blowby check all gaskets,and fillings run 3_1_2 QTS. Same problem.
Old May 20, 2014 | 11:57 PM
  #32
DeneFXDWG's Avatar
DeneFXDWG
I routed some hoses to a tee from my Ness Big Sucker, then to the ground. Will put some sort of a catch device on it this winter as it is embarrassing when I leave someone's driveway with an oil spot under my expensive Harley, simply dark age embarrassing, but it is what it is. You don't want to be routing that crap into the intake runners. Believe me when you take your TB off and look inside, it is gross.
Can't see how running the crank case low helps, tried that, (even drastically low), and still the same result.
Old May 21, 2014 | 12:57 AM
  #33
Mike's Avatar
Mike
The older Heavy Breather had single O-rings at the breather plugs, and they were prone to leaking. The newer versions have double O-rings, which has helped.
Old May 21, 2014 | 05:44 AM
  #34
rottweilerhog's Avatar
rottweilerhog
Well mine is a brand new 2014 103 with brand new everything and while I'm not experiencing oil on my freaking chaps and the need to add tubes and whiskey bottles and all of those other fine ideas, if newer means better, I guess that would be true in my case. Because mine is still leaking, but it's more like just smudging. Once I clean it off, it's good for a couple of hundred miles and then you can see it kinda started again. So I guess based on the oil on the chaps story (LOL!), I guess I got it pretty good.
Then there's the earlier conversation in this post about the dealer said it, so that's the end of it. LOL! That exchange was pretty funny. Anyways, quick story, I changed out my bars to 14in. apes and had to take my bike to the dealer to get my ABS fluids purged and ECM reset and the dealer says one of your new wheels (23in. front, 18in. rear) is throwing the code because it doesn't have an ABS bearing. The dealer says, "it's the front wheel". "Look, you can see it." And then said, "these are the wrong bearings."
So I called the manufacturer who made my wheels and nearly killed him over the phone for swearing the dealer was an idiot. Then I took it to a private mechanic near Atlanta who found it was the rear wheel with the wrong bearings and it was the rear wheel that was throwing the code. And it truly was. Freaking dealer? Ya ok. Cuz they're special right?
Old May 28, 2014 | 05:56 PM
  #35
scottma978's Avatar
scottma978
well I can't speak for anyone else, but my '07 Streetglide with a 96", has leaked since I put the heavy breather on four or five years ago…..and it is definitely from the two chrome plugs with the o- rings. Why is it when I had a regular screaming eagle stage one filter (and before that, the stock one if I remember correctly) had a rubber grommet that fit over each breather bolt and directed any blow by back into the throttle body to be burned off, yet the heavy breather doesn't have this?
Old May 29, 2014 | 06:34 AM
  #36
rottweilerhog
Sounds like we've reached the wall on the subject. On that note, can I just say...@scottma978, "if it ain't broke, fix it till it is" is prolly one of the funniest things I've ever read. Good one.
Old May 29, 2014 | 09:55 AM
  #37
sfcmo357's Avatar
sfcmo357
On the last 300 miles or so of a 2,000 mile trip a few weeks ago---I had this issue with my AN Big Sucker. I've never had this before...but I had never ridden 2,000 miles through the mountains and into Canada and back. The oil was coming out of the mounting poins-----------I went to a local shop, ordered new O-rings and gasket--took everything apart, cleaned all contact areas, even took a pik and cleaned out the threads ....took the same pik and cleaned off the threads on the bolts (yep--had too much loc-tite on)....put it back together, bought a pack of panty liners and put them inside my cover---I haven't had any oil leaking yet. So, I'm not sure if I fixed the problem or if the 2,000 miles at sustained RPMs and drastic temp changes had something to do with it----40s, 50s, back East at 70s (temps) .....also, my oil only reaches 1/2 way on the stick at hot check---I don't run at the top of the stick and I still had this blow by, so overfilling wasn't the issue.
Mac-427
Milwaukee Eight (M8)
Jan 10, 2026 06:06 PM
SGT89EVO
EVO
19
Mar 7, 2021 11:13 PM
510eastbay
Nov 25, 2014 07:50 PM
FatherNikki
Exhaust System Topics
21
Apr 7, 2011 11:59 AM
128auto
May 31, 2007 05:29 PM
