1990 flhtc no headlights radio
Old Jun 13, 2014 | 04:04 PM
monkeyvomit's Avatar
monkeyvomit
Stage II
Default 1990 flhtc no headlights radio
1990 flhtc, rode yesterday and noticed the volt meter would go to zero for a split second and then return to normal. got home, noticed no headlight, radio will not turn on, does have clock display reads 12:00, and click coming from under fairing that coincides with volt drop. clicks when it drops and when it returns. does this about every 45 seconds with ignition on and bike not running. help
Old Jun 13, 2014 | 04:17 PM
mkguitar's Avatar
mkguitar
click is probably a circuit breaker tripping and self-resetting.
the voltmeter in your dash is subject to voltage drop as it is on the same circuit as the lights, radio etc.
use a 'real' volt meter at the battery and confirm that at 3000 rpms you are over 13 volts- no higher than 14.8
mike
Old Jun 13, 2014 | 05:24 PM
hdbob2006's Avatar
hdbob2006
Sounds like a bare wire touching ground somewhere.
Old Jun 15, 2014 | 06:10 PM
machinehed's Avatar
machinehed
You have a short to ground in the circuit you describe .
Your circuit breaker is tripping as it is desighned to do.
Check the circuit wiring for a short to ground.
harleyd1500
Audio Systems
Jan 26, 2018 08:43 AM
WNMORE
2014-2024 Touring Models
11
Nov 6, 2017 05:22 PM
customchris2005
Dec 1, 2014 09:39 PM
Mike07FLHTC
Apr 1, 2010 06:36 PM
dolfan
May 15, 2006 01:59 PM
