code 16 battery positive voltage
Old Aug 16, 2014 | 02:36 PM
Barbarian15's Avatar
Barbarian15
Default code 16 battery positive voltage
my 98 road king is having starting problems, first it was crank positioning sensor, I have replaced the sensor, now i am getting a 16 battery positive voltage code. I don't know what to do now, any help
Old Aug 16, 2014 | 06:48 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Clean all your connections to the starter and to ground from the battery. I am assuming you have a good or maybe new battery? If you don't, then start there.
Old Aug 16, 2014 | 07:52 PM
rmc115's Avatar
rmc115
check your running voltage, anything over 15 volts sets a fault. Mike
Old Aug 16, 2014 | 07:59 PM
Def Mute's Avatar
Def Mute
Remove battery connections, and charge the battery...
with a real charger, not a tender. Clean battery post bolts, and cable eyelets. I got the same codes on my 99 RK, checked the cables at the battery and they felt tight. Changed the sensor, and still had codes. Went back to battery, and found one bolt had been loose for a while evidently. The arching of electricity had welded the bolt/nut together on the positive post, so that's why it felt tight. After replacing the bolt/nut, clearing codes, all was well again.
May not be your problem, but removing/cleaning connectors like mentioned above is good ideal...
Old Aug 17, 2014 | 11:19 AM
Barbarian15
thanks for the ideas
Old Aug 17, 2014 | 11:22 AM
mkguitar's Avatar
mkguitar
if you see over 14.8 volts measured at the battery with the motor at 3000 rpms, the voltage regulator is bad.
complete charging system diagnostics are on the tech board/ electrical.
all you need is a voltmeter
mike
Roni
Aug 5, 2024 05:13 AM
Bobber Jay
Jun 16, 2019 05:38 PM
skully1200
Mar 8, 2012 10:06 PM
slipvayne9278
Jul 22, 2011 12:39 PM
fuzzko
Nov 14, 2005 04:46 PM
