Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
What the Hell?
Old Jan 5, 2016 | 05:22 PM
Que Tip's Avatar
Que Tip
Default What the Hell?
After checking the Harley Forums, YouTube and Manual on changing handlebars. I decided I would give it a try installing the 10"Twin Peaks. If your not familiar with the Peaks they have 90 degree bends. The stock bar controls wires are external, the Wires by Throttle inside. Upon removing the protective tubing, I found a couple of butt connectors. One on each side and a split connector on the Throttle side. Thus the Title. The connectors were positioned about were the Peaks bend. I should of taken the easier way, cut and splice but I used brute strength. Now I'm a little worried if I didn't break a wire. Time will tell. Pray for me!
2010 FLHXXX
Old Jan 5, 2016 | 05:50 PM
TriGeezer's Avatar
TriGeezer
I'm kringing.
Hopefully you'll be ok...but if you're not, you'll know.
Old Jan 5, 2016 | 09:27 PM
Fearless (old nickname)'s Avatar
I will keep you n my prayers.... Khrome Werks 2+2 wide sweepers
Old Jan 5, 2016 | 09:31 PM
sloufoot's Avatar
sloufoot
Inside the handlebars & especially on the controls is not a place for "but connectors" !
They should be done with solder & heat shrink tubing. I would hate to be in the middle of nowhere & have that connection fail.
That other connector that slides together is a problem area also. I left the one in mine, but silicone greased it up well & put small wire ties around it.
Just say'n....
Old Jan 6, 2016 | 06:43 AM
Mr. Wizard's Avatar
Mr. Wizard
The SE throttle control has longer wires and eliminate the connectors.
Trust me... that little green connector will leave you stranded on the side of the road.
Old Jan 6, 2016 | 09:35 AM
Bubba49's Avatar
Bubba49
Just make sure you've got a full tool kit when you hit the road, because that connector will eventually find a way to come loose. Especially with all of the rattling a Harley does.
Bubba
Old Jan 7, 2016 | 07:11 AM
Que Tip's Avatar
Que Tip
Default butt connectors
The Trike had 3k miles and purchased from a Dealer.
I doubt they did it. Both sides? I'm thinking Harley was trying to save a dime.
Old Jan 9, 2016 | 04:03 PM
Gunnysgt's Avatar
Gunnysgt
One little trick I've done with the green TBW connector after several bar changes was to first make sure it's plugged back in properly and snug, after that I put a big piece of shrink tube over that green connector and shrink it tight. Never had an issue after doing that. There are no butt splices on any new harley in the bars from the factory I know of. Someone was playin in there
Old Jan 9, 2016 | 05:55 PM
Default yep
That is what I did on old shiney my first bar job and my last I hope not hard just like the change that well. ride safely fearless
Old Jan 9, 2016 | 08:49 PM
Gunnysgt's Avatar
Gunnysgt
I never was a fan of butt splices, even on kits that come with them. Solder and shrink wrap is the ticket for reliability. On the rare cases I have used them, after making sure the crimp is solid, I fill both ends of the butt splice with silicon sealer
Danny Licht
Jun 8, 2018 06:42 PM
TripleB
May 27, 2016 02:59 PM
kizzletruck
Jan 21, 2015 06:53 AM
Schwanz583
Nov 18, 2010 04:10 PM
mja52403
Feb 21, 2009 06:56 AM
