Bearing Change out
The outside one is easy, just use your tool normally, but tape up those Fingers on the Bridge because it meets the pulley radius (instead of the flat) and still may make small marks where fingers rest on the pulley.
It becomes more clear when you have everything in your hands
As I have had a lesson with you recently regarding which side of wheel hub is primary side ,, maybe you could expand my knowledge with a simple question regarding rear drive sprocket bearings, which is appertaining to this thread …
Having removed the two bearings that are stacked on top of each other in rear drive sprocket ,,,,, When installing new bearings,, (numbers facing out),,, first bearing gets seated to lip, (cant go any further),,,,, second bearing gets installed so is firmly seated on top of first bearing,, then stop …. Is this the correct procedure ??
Thanks in advance ….
Having removed the two bearings that are stacked on top of each other in rear drive sprocket ,,,,, When installing new bearings,, (numbers facing out),,, first bearing gets seated to lip, (cant go any further),,,,, second bearing gets installed so is firmly seated on top of first bearing,, then stop . Is this the correct procedure ??
Thanks in advance .
https://www.hdforums.com/forum/wheel...l#post18049672
