Different tire heights
Old Apr 28, 2022 | 10:06 PM
Ktowndave's Avatar
Ktowndave
Stage II
Default Different tire heights
I have a 2003 Road King and front and rear tires are supposed to be the same. My question is: can I use a stock size 130/90-16 on the front and a 140/90-16 on the rear?
Old Apr 29, 2022 | 09:56 AM
dfwhockey17's Avatar
dfwhockey17
Yes you can
Old Apr 29, 2022 | 10:56 AM
smitty901's Avatar
smitty901
the 140 is about 6 to 7 tenths higher and about 4 tenths wider. At 60 mph speedometer error is 1.7 MPH
Old Apr 30, 2022 | 06:35 AM
Ktowndave's Avatar
Ktowndave
Stage II
Default Odometer
Doesn't the speedometer use the front wheel? If it does, the speedo ratio would be the same, as long as the tire is exactly the same dia. I will gain a little more top end speed but lose a little hp.
Old Apr 30, 2022 | 08:42 AM
smitty901's Avatar
smitty901
Depends on the bike . HD mover away from the front speed cable some time back. Not even my 1996 use it. it uses a senor in trans. You will not lose any HP the change is so small you can not measure it.
Old Apr 30, 2022 | 09:31 AM
dfwhockey17
Because 1996 is the first year of the electronic speedo!
Old Apr 30, 2022 | 02:58 PM
smitty901's Avatar
smitty901
Well then his 2003 does not use a gear driven cable.
Old Apr 30, 2022 | 03:20 PM
Y2K's Avatar
Y2K
Belt clearance will be tight but it works,I ran 140's on my 2000 Electra for hundreds of thousands of miles and 20 years.
bulldog1776
Dec 9, 2021 09:35 PM
styck.shyfter
Wheels/Tires
Dec 22, 2020 01:13 PM
Barbarian15
Wheels/Tires
Mar 15, 2013 04:27 PM
gtrplyr
Oct 28, 2011 05:00 PM
LouisM58
Feb 23, 2011 10:48 AM
