Dunlop ae
Old Apr 24, 2022 | 04:07 PM
bassnman's Avatar
bassnman
Default Dunlop ae
Recently installed a Dunlop AE on the front of my 2013 ultra, I have been using Dyna Beads for about 10 yrs & never had an issue.
Long story short, the shop that did the install never heard of the beads, so I had to teach them about the "Birds & the Bee's".
This tire does not have a Dot on it anywhere, how ever the tire does have the embossed lettering DOT, which is 180* way from the air valve.
The shop claims they added the 2oz of beads that I provide, I don't for sure??
However riding the bike it's very smooth till I hit 72mph, after that the front end shakes, so I added more bead's approx. 3more oz.
The front end still has the same problem, wheel bearings seem to be good, is it the tire or the balance?
Like I said I've used the beads for at least 10 yrs & never had an issue even on other brands of bikes.
Where should I start making corrections?
Old Apr 25, 2022 | 03:41 PM
LQQK_OUT's Avatar
LQQK_OUT
Dunlop street tires have balance dots in the bead or sidewall area to indicate the lightest point of the tire.
Tire Installation (see also Tire Mounting)
Wheel Balance
Old Apr 26, 2022 | 05:29 AM
eighteight's Avatar
eighteight
^ Department Of Transportation
( It`s on your head lamp also, but those usually don`t get balanced )
Old Apr 26, 2022 | 07:58 AM
bustert's Avatar
bustert
even with beads, imbalance can occur, reason i still use outside weights.
Old Apr 27, 2022 | 03:29 PM
peteperrone's Avatar
peteperrone
I have never heard of balance beads!
Old Apr 27, 2022 | 04:19 PM
TriGeezer's Avatar
TriGeezer
Ive run 2 sets of of tires with balance beads. I’m sold on them. I’ve never had any balance type issues. Smooth running at any speed.
Old May 1, 2022 | 04:17 PM
InthewindMN's Avatar
InthewindMN
At this point you probably have too much beads in it, I think they only recommend 1oz for a front tire depending on size.
Old May 1, 2022 | 05:41 PM
bassnman's Avatar
bassnman
the trouble w/ my AE was not the tire, it was the tech, no dot on the tire, it has a bar code on the bead that was 180* from the vale stem, thus the tire had to be rotated 180*, the tech added 2.1 oz of lead weights to the rim & the bike is fine..
DonN
Jul 29, 2015 10:43 PM
scot210
Jun 19, 2015 09:23 PM
brenn
Jul 5, 2012 09:33 AM
CKS
EVO
Sep 19, 2010 03:50 AM
