clank, clank, clank, what do I need to replace?
Old Jan 10, 2012 | 07:46 PM
dub976's Avatar
dub976
Default clank, clank, clank, what do I need to replace?
my front brake caliper makes a clanking noise while hitting some bumps. I did notice that with the bike parked I can move the caliper side to side and make the clanking noise. is there some kind of bushing that needs to be replaced?
Old Jan 10, 2012 | 09:09 PM
j1mmy's Avatar
j1mmy
the caliper does have bushings, but they arnt likely to be worn on a 10yo or less bike..the caliper floats, it will make a little noise.. grab each part on the front end and give it a shake. lights, tins, cowbells, bars, calipers, fender.. something might be loose.. don't worry about it too much,HD's are known for being noisy.. a loud distinct clanking could be a loose/missing bolt on the tins or fender. i have seen lots of cowbells get tweaked a little, then they hit the lower slider when it moves. you could hold the front brake and rock the bike back and fourth.. watch if the fork legs flex a little, very not likely on a newer bike but the bushings could be worn letting the sliders bang around and hit the cowbells..
Old Jan 11, 2012 | 12:05 PM
dub976's Avatar
dub976
I'm sure it's from the brake caliper. I can reproduce the same noise by moving the caliper back and forth while the bikes parked. I've checked the tightness of the two bolts holding the caliper on and they are nice and tight.
Btw the bike is a 99 fatboy so I'm leaning towards something in the mounting hardware. What do you think?
Old Jan 14, 2012 | 11:22 AM
95custmz's Avatar
95custmz
Check and make sure it's not your pads making that noise. Look for a broken or missing brake pad clip.
Surfit
General Topics/Tech Tips
May 2, 2014 10:20 AM
Edywazoo
Wheels/Tires
Jul 19, 2013 07:25 PM
JerseyDevil
Oct 3, 2008 09:16 PM
AKtanker
Jun 14, 2008 01:17 PM
69Shark
Feb 25, 2007 09:45 AM
