Michelin Commander ll Tire Pressures from Michelin!
(I hope it's of some help as I asked everyone and couldn't get a straight answer!)
http://motorsport.michelin.co.uk/for...9e90f260a#p261
"Hi Caddyman.
Thanks for your query, and pleased to hear you like the Commaders. Initial advice is as follows ( I am awaiting further info from our "2-wheel experts" in relation to rider weights).
Pressure for the Harley Davidson FLHTCU Electra Glide Ultra Classic (1548cc) 2009 - onwards, if on tyre sizes front 130/80 – B17 65H TL/TT (tubeless tube type) and Rear 180/65 – B16 781H TL/TT the tyre pressures (set when tyres are cold) should be as follows:-
Front – 36 psi (pounds per square inch)
Rear – 40 psi (pounds per square inch)
Please be advised to follow values indicated in the motorcycle handbook in relation to the tyre size fitted – specifications can change without our knowledge.
Will be in touch again when I have further info."
Regards
Mike (Michelin)
The reason I joined the Michelin Forum was just to get an answer from Michelin directly as to what the pressure should be as there is so much variation out there with different guys saying 36 up to 44psi.
It looks now like they won't or can't give a straight answer! Do you or anyone else out there reading this have them on your bike (especially a 2007-2009 UC) and if so what do you run them at?
The numbers you quote all seem to me to be within expectation, allowing for personal taste and taking into account solo and duo settings.
Heading to Spain on Monday for a weeks cruising around Andalucia and have hired a Yamaha Midnight Star so I must remember to bring my tyre guage and see what pressure she's running before I set off.
You like tomato and I like tomahto,
Potato, potahto, tomato, tomahto!
Let's call the whole thing off!
Hah ha....
