Primary Fluid Level
Old May 16, 2015 | 09:24 PM
  #41
mcouture's Avatar
mcouture
I let mine drain for about 5 minutes and when I stood it straight up and poured about 34oz it was up to the lip and started dripping out.
I'm not sure if the low models have a different capacity or what but it wasn't even close. I ended up taking a bit out and buttoned it up. It just a bit unnerving that the manual says 38oz and I put about 32oz ... but the level is the level so I'm not going to over think it too much...
Old May 16, 2015 | 10:25 PM
  #42
Kilokato's Avatar
Kilokato
I changed my primary oil today.
I took what oil came out and poured it into an empty 32 oz. SYN3 plastic bottle. It came very close to the top of the bottle-over 32 oz. obviously.
I opened a new bottle of SYN3 and filled it to the same level as the above with a 2nd bottle and then poured that whole extra full bottle in the primary. Looked like about 36 oz. (there was about 28 oz. left in the 2nd bottle) but it's the same amount I drained out.
I drained it with a 2x4 under the jiffy stand so it was close to upright.
Old May 16, 2015 | 10:28 PM
  #43
Bikerscum's Avatar
Bikerscum
I have a '15 Limited Low, I've changed the fluid maybe 5-6 times in 2 months experimenting with different ones. Always get 38 ounces in no problem.
Old May 16, 2015 | 10:31 PM
  #44
logical's Avatar
logical
Originally Posted by logical
I'm not sure why you are posting, you couldn't be more wrong. The primary case is the one cavity where there is a significant amount of fluid that stays in it when just using the drain plug.
I agree with what many have stated, drain it and pour in 38 ounces when doing normal maintenance, but the primary has a total of 45 ounces when property filled, 7 of which are below the drain plug and only accessible if you remove the entire outer primary.
Originally Posted by gwellis
You could not be more wrong. Dry refers to the oil retained on the surface of the clutch and compensating sprocket. While I agree there is an extra amount in the very bottom of the primary case, it does not matter whether you drain it standing up or on the stand! Empty is empty. How many inner primary seals, clutches or compensating sprockets have you done?? I am a mechanic. What is your livelihood? Thanks Grant.
I didn't say anything about standing it up or on the stand, you are confused about that. You are correct that the extra 7 ounces is not all below the normal drain level. I oversimplified that. No, I do not make a living as a mechanic but I do all my own work. I am incredibly slow at it so fortunately I have other marketable skills.
Old May 17, 2015 | 10:51 AM
  #45
gwellis's Avatar
gwellis
Sorry I blew up
Old May 17, 2015 | 11:27 AM
  #46
68 XLCH's Avatar
68 XLCH
A few weeks ago i changed all three. Each time i warmed up the bike between draining the engine, trans and primary. It was a cool morning in the garage and i am slow, methodical. I actually enjoyed the 4 or 5 hours i spent changing the oil and cleaning a few things.
I put 38 ozs of Formula plus in the primary and it brought i up to where it was before i drained it. Another thread had a picture and it was about there, maybe and RCH below that, but no where near coming out of the derby cover.
My bike is in a HD chock stand in the garage so it is always standing straight up. I used the Harley funnel, really not needed but it work as advertised.
Old May 17, 2015 | 08:35 PM
  #47
asg13's Avatar
asg13
Just changed mine as well. 38oz but swear finding neutral seems more difficult? Hell if i know
Old May 17, 2015 | 10:15 PM
  #48
logical's Avatar
logical
Harley suddenly decided that one fluid was perfect for all 3 cavities. That never made sense to me. I use oil in the engine (I use Redline synthetic but won't try to change anyone's mind about Amsoil, Betray, Mobile 1 or Harley Branded oil...any good synthetic oil is fine) but I've used Redline MTL in my primaries and Redline Shockproof Heavy in the trans for 15 years. In every bike it has made shifting smoother and neutral much easier to find.
elb62
Screamin Eagle CVO Models
Mar 31, 2016 05:24 PM
Scottyrr
Jun 28, 2013 10:36 AM
Electra1
Oct 23, 2011 09:17 AM
fatbob
Jun 15, 2008 07:41 PM
firestar99
Jul 28, 2006 02:03 PM
