No Clunk
Old Jun 11, 2015 | 04:45 PM
  #31
Afdharley's Avatar
Afdharley
I believe that clunk is trans dropping into first gear. Personally, I run red line products in all 3 holes.
Old Jun 11, 2015 | 05:41 PM
  #32
YPD485's Avatar
YPD485
The first gear clunk is from the primary chain tightening up.
Old Jun 11, 2015 | 08:12 PM
  #33
Bikerscum's Avatar
Bikerscum
Originally Posted by IUOE ROB
Kinda wondered about that too, I thought the clunk was a transmission thing. And as I stated, my goal is to cut down primary noise and that's why I'm trying the R/L Primary oil.
The klunk is the sound of the "dogs" on one gear sliding into the "holes" on the next gear over in the transmission. More or less.
BUT, what causes the klunk into first is the clutch. Ideally, the transmission mainshaft that goes to the clutch shouldn't be spinning at idle. The transmission isn't, so the dogs slide right in silently. Think about when you shift into first with the engine off... no klunk.
In reality, even though you disengage the clutch, the plates stick together with the oil film between them, and if the engine is idling at 1,000 rpm, the mainshaft is turning at 1000 rpm... there's no resistance to stop it. Shift into first and the gear (dogs) on that spinning mainshaft have to slide into the holes on a stationary gear, and go from 1000 rpms to zero in an instant.... KLUNK.
The solution is to find a lube that prevents the disks from sticking together. Different lubes seem to work for different people. For me, nothing beats synthetic ATF. My advice is try them all, see what works for you.
Oversimplified to be sure, but that's the gist of it.
Old Jun 11, 2015 | 08:20 PM
  #34
EdandGrace's Avatar
EdandGrace
Does the Klunk hurt anything or just sounds like it does?
Old Jun 11, 2015 | 08:24 PM
  #35
IUOE ROB's Avatar
IUOE ROB
Thanks for taking the time to explain this...
Old Jun 11, 2015 | 09:01 PM
  #36
perki48's Avatar
perki48
That is the best laugh I have had all day.
Old Jun 11, 2015 | 09:24 PM
  #37
RG Pilot's Avatar
RG Pilot
You are joking, right?
Old Jun 12, 2015 | 09:03 AM
  #38
68beep's Avatar
68beep
I've always thought it was the compensator.
Old Jun 12, 2015 | 08:38 PM
  #39
YPD485's Avatar
YPD485
Yes, I forgot to add the smile icon.
Old Jun 12, 2015 | 08:42 PM
  #40
RG Pilot's Avatar
RG Pilot
I figured.....and hoped!!!
