Engine issue?
Old Aug 15, 2020 | 08:17 PM
Drtumolo's Avatar
Drtumolo
Default Engine issue?
My 2016 streetglide (47k miles) started making a new noise on trip home from sturgis. When starting it has what sounds like a lifter noise for a few seconds. Also when you decelerate quickly it sounds like an engine rattle. I plan to start investing tomorrow but looking for ideas on where to begin.
Old Aug 15, 2020 | 08:28 PM
CoolBreeze3646's Avatar
CoolBreeze3646
What is your oil level like? And how many miles are there on the oil?
Old Aug 15, 2020 | 08:40 PM
Drtumolo's Avatar
Drtumolo
Oil level shows full and 5000 on oil. Mobile one with k&n filter
Old Aug 15, 2020 | 08:43 PM
CoolBreeze3646
The oil may be breaking down a little. Once you get home change it and see if the issue goes away.
Old Aug 15, 2020 | 09:01 PM
Drtumolo's Avatar
Drtumolo
I plan to change it tomorrow but when I talked to mobile rep at sturgis he felt 5000 miles or even 8000 miles would not be an issue.
Old Aug 16, 2020 | 10:48 AM
CrBear's Avatar
CrBear
I had the same sounds after a recent 11 day 4600-mile trip. Changed oil, air filter, and plugs, and the sounds are "much" better..
Old Aug 16, 2020 | 11:11 AM
hattitude's Avatar
hattitude
Well...
Unless they have been changed out, you DO have the #18538-99C lifters... The OEM HD "C" lifters, as they are called, are generally considered sub standard (to be put kindly).....
Many people have had issues at less than 47K miles.... some have gone 100K miles with no issues
Most people (including me) will replace the OEM HD lifters anytime they go into the cam chest for anything.... tensioner repair, cam upgrade, etc... But they won't go into the cam chest, just to replace them...That is, barring a possible lifter issue....
You may be hearing the start of a lifter issue... Your lifters could be worn and they aren't pumping up and maintaining pressure like they used....
Not a huge job to replace the lifters, but can be time consuming depending on how you choose to do it... If you can't do the work yourself, the labor costs could be a few bucks....
Old Aug 16, 2020 | 05:32 PM
Drtumolo's Avatar
Drtumolo
So I did a little investigating today. The sound is coming from the primary area I think but sounds just like lifter. I also have a slight clunk on shut down coming from primary area. Bad compensator?
Old Aug 17, 2020 | 08:11 PM
Riding4theKing's Avatar
Riding4theKing
I have a 2017 CVO Limited that has been making the same noise and started about 15k, have 38k now. When starting sounds like an old chevy with low oil and will only last a few sec... I have had it looked at by dealer but like everything else, they say that's normal. I say BS on that.
Old Aug 18, 2020 | 04:43 AM
Drtumolo's Avatar
Drtumolo
I changed out all the oils to amsoil and it is quieter. The noise is still there at times but not nearly as loud.
johnnyhumble
Jun 1, 2020 07:35 PM
flyboyron
2014-2024 Touring Models
16
Jan 4, 2015 07:47 AM
the4thgearkid
Jun 2, 2013 02:51 PM
KIRBYSDAD
Exhaust System Topics
Mar 25, 2013 08:56 PM
stbobfisher
May 28, 2009 06:31 PM
