2018+ Softail Models Breakout
The Everything 2018+ Heritage Thread
Old Apr 26, 2019 | 01:12 AM
  #1461
Steve Sportster's Avatar
Steve Sportster
I hear the same thing on my 2018 FLHCS. Jacked it up and spun both wheels to make sure I didn't have a bad bearing. Both front and rear seemed fine and I heard nothing from the calipers. Living with it for now.
Old Apr 26, 2019 | 07:44 AM
  #1462
sectime's Avatar
sectime
Mine just came back from the dealer for a rocker box leak and third attempt since new to fix this noise, or rather not fix. Two belts, brake pads front wheel bearings same noise, early on in this thread people fixed it by working with the belt guard, this time they again adjusted belt was quiet for about 10 miles. It was cold so I just turned up my new heated grips and the noise almost went away
Old Apr 26, 2019 | 01:04 PM
  #1463
Parrothead1809's Avatar
Parrothead1809
Does anyone know if HD makes a Rider Back Rest that fits with the stock '18 or '19 Heritage seat? From what I can tell they don't. If you have one, where did you get it? I used http://www.grasshopperlimited.com/ for my current (non HD) bike.
Also, can I remove the pillion and install a backrest WITH a fender luggage rack (I won't be doing any 2-up). Anyone with pictures that show any variation of this, please share!!
Thanks,
-PH
Old Apr 27, 2019 | 12:59 AM
  #1464
Phil13's Avatar
Phil13
HD only do a rider back rest for the Sundowner as far as I know. Grasshopper do make a back rest for the '18 onward Heritage which uses the two studs that secure the riders seat. With a seat, backrest and a rack it would be a close call whether there was enough length left in the studs to be able to secure all three with the thumb screws.
Old Apr 28, 2019 | 09:05 AM
  #1465
Parrothead1809
Thank Phil, that's what I thought. It looks like you go without the passenger seat. I like that clean look as well.
From looking at the solo seat luggage racks, its hard to tell if those actually use those same thumb bolts. I guess I could add the rack that the tour box uses (since I don't believe that uses the same seat thumb bolts). I'm just looking for some place to bungee some gear too big for the saddle bags when I do a camping trip (tent, sleeping bag, pad, etc.).
Thanks again,
-PH
Old Apr 28, 2019 | 05:48 PM
  #1466
DonN's Avatar
DonN
I put on a leather bib and have the grasshopper and barely have enough threads on the bolt so really doubt a motherwell or similar luggage rack will fit with both. Can just get another bolt 1/2" longer, but may need to lift the rear high enough to get some small hands under the fender to replace.
The tour pack mounts on the saddlebag struts so wont use the same bolts. But I think it looks ugly by itself and replacing the thumbscrew bolts much simpler solution.
Old Apr 28, 2019 | 06:52 PM
  #1467
Pothole914's Avatar
Pothole914
I have a fender bib from Capt Itch, a motherwell rack and the grasshopper back rest. No problems. The motherwell rack slips on the seat bolts, not under them. Same as the passenger seat.
Old Apr 29, 2019 | 04:09 AM
  #1468
MHTR's Avatar
MHTR
Parrothead1809,
I also have the Grasshopper backrest & a Motherwell rack. Uses the same seat fasteners and works great. It's a long story, but I have a second new-in-the-box Grasshopper backrest for a '18 Heritage. Gimmie a shout if you're interested.
Old Apr 29, 2019 | 07:32 AM
  #1469
Parrothead1809
Sure thing. I’ve gotta get the bike first
-PH
Old Apr 29, 2019 | 11:49 AM
  #1470
LTBiker's Avatar
LTBiker
I have a basically brand-new Motherwell solo rack, gloss black, with fender rear bolt/screw. Don't need it any longer. Save you a lot of money over buying a new one. PM me if interested.
